Author Topic: Ceramic capacitors  (Read 3539 times)
Offline BurningTantalumTopic starter
Ceramic capacitors
« on: January 07, 2023, 05:27:01 am »
I found a small bag of ceramic capacitors in one of my component drawers. I have no idea where they came from.
What would their application be, and how would they be mounted/connected? The circular ones are 1.3mm thick and measure around 1n2. The trapezoid ones are labelled as 1n.
Offline srb1954
  • Retired Electronics Design Engineer
Re: Ceramic capacitors
« Reply #1 on: January 07, 2023, 06:22:39 am »
The trapezoidal ones are designed to be wedged into a slot in a PCB and blob soldered on each side so that there is zero effective lead length and practically zero ESL.
The round ones could also be mounted in the same way but I have also seen them soldered face down onto a PCB for a very low inductance bypass capacitor with other components air-wired to the top face.
Offline bidrohini
  • Country: bd
« Reply #2 on: January 07, 2023, 07:37:56 am »
Could you please tell us how to solder these capacitors? I cannot see any legs like usual capacitors.
« Reply #3 on: January 07, 2023, 08:53:44 am »
Thanks SRB, that makes perfect sense. I guess they will go back in the drawer they came from!
Offline srb1954
« Reply #4 on: January 07, 2023, 09:01:46 am »
The slot in the PCB has Cu tracks right up to the edge of the slot. A blob of solder bridges from the Cu track to the side of the capacitor.
Offline Alex Eisenhut
  • Place text here.
« Reply #5 on: January 07, 2023, 06:35:25 pm »
Wow, I think Tektronix used these in the 1960s in the 1S1 and 1S2 GHz samplers. Never seen them as loose parts.
Online SiliconWizard
« Reply #6 on: January 07, 2023, 10:27:30 pm »
Nice piece of history.
