Oklay...
just happened here...?
I generally tend to agree with Oculus' surmise; ogden has been nit-pick trolling the thread pretty hard, and unless joe is outright lying, he has a history of thread-stalking joe.
Joe's response, while it may have been viscerally cathartic, was def a bit OTT for a public space; it should've been toned down or if the venting was necessary, taken to PM.
But seriously... this is a pretty obvious case of personality-clash oscillation. This is hardly new territory; we've been dealing with this kind of passive-aggressive back & forth since the days of UseNet and the solution is pretty well-established: BOTH parties are responsible. Not JUST the troll, and not just the one(s) feeding the troll. Either both/all or none should be given a time-out. That is why we call it a time-out: Not a punishment, but forcing all parties to step back and consider their contribution to the NOISE part of the SNR.
That said... Joe, when you get back, we SERIOUSLY need decently-focused pictures of the ENTIRE circuit. It's delicious to see those numbers, but part of the OP's rules were that the entire circuit needs to be SEEN to count; and it seems obvious to me that requires pictures of the entire circuit rendered clearly enough that someone else COULD duplicate your circuit and results (or at least come close) in a double-blind fashion. So far we have NOT seen any of your circuits in this level of detail.
If your circuit requires the Faraday cage, cool. We need documentation-quality pics of the actual circuit before and after the cage is applied. Preferably decent resolution video of the cage IN ACTION; if the circuit works but needs the cage to get your results, you should be able to demonstrate that in real-time.
BreakingOhmsLaw, I humbly submit that while joe's results ARE impressive, PA0PBZ is correct: He simply has not given reasonable proof that his actual circuits ARE what he claims they are.
Okay... I'm going to go back to lurking and tossing peanut shells now; this "being the voice of reason" thing is quite taxing.
