Hi everyone,
I'm doing a small assignment about class D amplifier, but I'm confused while calculating the gain of its. As my teacher said that the gain of class D only depends on the rail voltage, which is ± 150V in this case and the amplitude of the triangle Vtr should be larger than Vaudio_amp_peak about 80%. So with Vaudio_peak is about 46,5V (at t=), Vtr should be 80,5V. But when doing FFT (with the setting - Number of data points samples in time: 16777216 and Windowing Function: Flat-top), i know that Vtr also affect the gain of the amplifier.
