Hmm, damn, was just looking at the exact inductor you mentioned (has about 22 turns). There is another larger one there with a couple of windings it looks like.
OK - The PWM frequency options I have are: 62.5Khz, 31.250Khz, 7.812Khz, 3.910Khz, then a few at even lower frequencies.
When I tried running the fan on the 2 highest frequencies directly, they didn't do anything at all, so I was a bit concerned about using them. However if the filter is going to be smaller/easier/more efficient at higher frequencies (and give me a smoother output), then that's great.
I've tried looking online for low pass LC filter calculators, but there seems to be many different configurations, I can't really find any with just the single inductor, cap and diode. Does anyone have any links perhaps?
I'm just a bit confused as to what I'm actually aiming for here - in terms of ripple attenuation values etc.
I've basically never used inductors in my circuits before, so I was a bit hesistant about the LC filter, but seems like what I'm going to have to go with. Just not sure what component values I'd need to go with assuming those higher frequencies? Are inductors rated purely by Irms? So in my case, I'd aim for something around 6A? Would 62Khz and 32Khz work better with ferrite or powdered iron inductors etc?
Cheers
