Author Topic: Connection detection?  (Read 13311 times)
Offline void_errorTopic starter
Re: Connection detection?
« Reply #25 on: May 14, 2015, 06:15:07 am »
Actually the problem was solved quite a while ago, see above and here. The only thing I didn't know how to do is detect which two sockets are connected together.
I can transistor...
Offline SL4P
  • There's more value if you figure it out yourself!
« Reply #26 on: May 14, 2015, 06:21:12 am »
Ok, so you're good. (Sorry I missed post #15)
Post your block schematic and we can add / comment on your plan.
What you need to be prepared for is using pins for BOTH in and out at different times - or spring for a larger pinout package.
Don't ask a question if you aren't willing to listen to the answer.
« Reply #27 on: May 14, 2015, 10:08:31 am »
No need to, I've tested it and it works. Already done writing the code for it. Next step is designing a PCB. Did I mention this has to be 2xAA battery powered? Using a MCP1640 to boost the voltage.
Easy. Used the TRIS registers to change pin direction when needed.
« Last Edit: May 14, 2015, 10:11:25 am by void_error »
I can transistor...
