I got a couple of air handler blower motors after replacing the home a/c sys. Wired one up to run on high speed. Connected it thru a amp meter to 120V. Motor is rated at 7.2A on high speed. My amp meter is reading 10A and every 20 secs or so, it would hiccup and pull ~11A for a half sec or so. Figured it was shot, then A/C guy says it needs duct work attached for it to run right. Started covering the outlet with a metal plate to create the back press it needs. Sure enough amperage dropped to 6A after covering abt 1/4 of the opening. Left it running for a few hours and it sounds happy. A/C guy also mentioned he had ran one with no duct-work and it burned up after a few hours.
Started thinking abt the current and voltage peaks being out of phase. I'm assuming since a motor is inductive, if I increase the load on the motor (by partially blocking the outlet), the inductance will increase. The run capacitor is sized with a certain load assumed on the motor. If I run the fan with no blockage of the air, there's less load, so there's less inductance and now the run cap is too big.
Am I on the right track here? Will motor be happier with less capacitance when run with no ductwork?
