Author Topic: Digital Interface  (Read 2029 times)
Offline project345Topic starter
Digital Interface
« on: May 11, 2025, 05:23:06 pm »
Hi
I have a logic circuit that requires an interface. The interface needs to be capable of accepting a sine, square, pulse, triangle, ramp or sawtooth wave with a voltage range of 0 to 25 volts at anywhere from 1 Hz to 60 MHz. The output side of the interface must be a 0 to 5 volt squarewave at the same frequency as the input signal. At the same time, the interface must be able to protect the circuit from over-voltages and negative voltages.
Can anyone provide a circuit schematic for such a circuit?
Thanks
Offline tggzzz
Re: Digital Interface
« Reply #1 on: May 11, 2025, 05:46:53 pm »
Hi
Is this coursework and/or homework? If so, it is polite to state that.
If not, then more information would be beneficial, e.g. purpose, EMI/EMC constraints, allowable jitter, etc.
« Reply #2 on: May 11, 2025, 06:43:12 pm »
It is not homework you fucking asshole!
Offline pcprogrammer
« Reply #3 on: May 11, 2025, 06:49:38 pm »
Yeah, that is a good way to start to get a community to help you.  :palm:
What is wrong with you people. tggzzz just asked for more information and this is what he gets.
For the community additional information is needed to provide a proper answer to this question of yours. If it where homework a more simplified circuit would suffice. For something that is going to be sold into either a home market or a professional one, there are standards to adhere to.
But in this case my answer is, go and try chatgpt or grok. Maybe it will provide you with something you can use.
Offline tggzzz
« Reply #4 on: May 11, 2025, 07:35:05 pm »
Noted.
The following users thanked this post: voltsandjolts
Offline Doctorandus_P
« Reply #5 on: May 11, 2025, 08:34:25 pm »
With such an answer to a reasonable assumption / question I'm out.
My suggestion is you work a bit on your social skills first.
« Last Edit: May 11, 2025, 08:42:15 pm by Doctorandus_P »
The following users thanked this post: pardo-bsso
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #6 on: May 11, 2025, 08:58:20 pm »
Hey a*****e, good luck on the forum, oh and if you think you are going to just setup one account after another as you piss people off with what I assume you consider a disposable addresses like the one you seem to have on this account you are out of luck!
Offline Benta
« Reply #7 on: May 11, 2025, 09:01:32 pm »
Way to go, Simon!
No one needs this kind of behaviour. I had the impression that Canadians are polite.
Offline tggzzz
« Reply #8 on: May 11, 2025, 09:06:28 pm »
Way to go, Simon!
Mensch ist mensch, the whole world over.
Canadians typically are nice, but displaying a Canadian flag doesn't mean he is Canadian. False flags are common on the forum; some uses are valid, but...
Offline Simon
  • Global Moderator
« Reply #9 on: May 11, 2025, 09:14:08 pm »
Yea, given the disposable nature of the email address I would not put any money on their location flag.
Online EEVblog
« Reply #10 on: May 12, 2025, 12:50:05 am »
He asked politely for you to clarify.
"Is this coursework and/or homework? If so, it is polite to state that. "
Hurling abuse two posts in isn't going to get you far here.
The following users thanked this post: PCB.Wiz
Offline jeremy0
« Reply #11 on: May 14, 2025, 07:13:12 am »
Definitely homework.
