Author Topic: Diy Hot Plate  (Read 4572 times)
Offline Arcamax123Topic starter
Diy Hot Plate
« on: June 23, 2016, 04:22:13 am »
I am planning on making a hot plate with a chunk of aluminium on top... I would like some ideas on how to do this.
Re: Diy Hot Plate
« Reply #1 on: June 23, 2016, 04:38:52 am »
How about some design specifics. Size, max temp, heat rate, power supply (AC/DC voltage power)? Plate thickness. Why Aluminium? What sort of temperature control do you need?
What do you want to heat?
Well I guess it doesn't need to be aluminium. I want to stick something on top to heat things up with... a lower temperature, 6 or 7inch square maybe. Need options lol
Offline nali
Re: Diy Hot Plate
« Reply #2 on: June 23, 2016, 06:26:05 am »
There are tons of heated beds available for 3D printers about that size, try searching Reprap heated bed.
Offline ion
Re: Diy Hot Plate
« Reply #3 on: June 23, 2016, 08:09:35 am »
I made a one like this last year - I used aluminium to make the machining easier with the limited tools I have.
The exact design will depend on what you want to do with it, but you can make a basic hotplate using the aluminium, cartridge heaters and a PID temperature controller.  If you use mains powered heaters make sure you earth the hotplate and use a fuse too.
Offline Ian.M
Re: Diy Hot Plate
« Reply #4 on: June 23, 2016, 08:52:41 am »
Its slightly bigger than you want, but you'd have to put in a lot of work to beat something like: https://www.amazon.com/Presto-07211-Liddle-Griddle/dp/B00006IUWL
Re: Diy Hot Plate
« Reply #5 on: June 23, 2016, 09:57:41 pm »
I wonder... can I use an old stove top element some how?
Offline uncle_bob
Re: Diy Hot Plate
« Reply #6 on: June 24, 2016, 12:35:24 am »
Hi
You can buy hot plates on eBay or Craigs List  for next to nothing at all. Unless you already have a pile of parts ready to go, $10 or $20 spent there is the best bet. What does your design need to do that the used commercial unit does not do?
Bob
