EEVblog® Electronics Community Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Dual series switch diodes
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Dual series switch diodes (Read 1480 times)
anishkgt
Frequent Contributor
Country:
on:
September 29, 2017, 10:31:59 pm »
hi All,
For the attached schematic the series diode D8 were 1N4148 in a series configuration. Since i was running out of room on my PCB i was thinking replacing them with an off-the shelf 'Dual Series diodes' (
https://www.digikey.com/product-detail/en/on-semiconductor/BAV99LT3G/BAV99LT3GOSCT-ND/1967036
). I am just not sure if the specs match. The Max forward Voltage for 1N4148 and BAV99LT3G are
1V @ 10mA
and
1.25V @ 150mA
respectively. Seems like they would fit.
need a second opinion on this.
Thanks in Advance.
Logged
T3sl4co1l
Super Contributor
Country:
Expert, Analog Electronics, PCB Layout, EMC
Re: Dual series switch diodes
Reply #1 on:
September 29, 2017, 10:33:23 pm »
BAV99 is an excellent part to have in stock, for just situations like this, yes.
Logged
Seven Transistor Labs, LLC
Bringing a project to life? Send me a message!
anishkgt
Country:
Reply #2 on:
September 29, 2017, 10:35:36 pm »
Thanks that was quick
Logged
anishkgt
Country:
Reply #3 on:
September 29, 2017, 10:39:19 pm »
A bit off subject, i am just getting used to opamps, actually learning as i work with them. The gain control is done by the pot R23 and eliminating R24 gives a the same output, named 'iSense'.
Would it be ok to eliminate it ?
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog® Main Site
EEVblog® on Youtube
EEVblog® on Twitter
EEVblog® on Facebook
EEVblog® on Odysee
