Author Topic: Dual series switch diodes  (Read 1498 times)
Offline anishkgtTopic starter
  • Country: qa
    • George Hobby
« on: September 29, 2017, 10:31:59 pm »
hi All,
For the attached schematic the series diode D8 were 1N4148 in a series configuration. Since i was running out of room on my PCB i was thinking replacing them with an off-the shelf 'Dual Series diodes' (https://www.digikey.com/product-detail/en/on-semiconductor/BAV99LT3G/BAV99LT3GOSCT-ND/1967036). I am just not sure if the specs match. The Max forward Voltage for 1N4148 and BAV99LT3G are 1V @ 10mA and 1.25V @ 150mA respectively. Seems like they would fit.
need a second opinion on this.
Thanks in Advance.
Offline T3sl4co1l
    • Seven Transistor Labs
Re: Dual series switch diodes
« Reply #1 on: September 29, 2017, 10:33:23 pm »
BAV99 is an excellent part to have in stock, for just situations like this, yes. :)
Seven Transistor Labs, LLC
  • Country: qa
    • George Hobby
« Reply #2 on: September 29, 2017, 10:35:36 pm »
Thanks that was quick :)
  • Country: qa
    • George Hobby
« Reply #3 on: September 29, 2017, 10:39:19 pm »
A bit off subject, i am just getting used to opamps, actually learning as i work with them. The gain control is done by the pot R23 and eliminating R24 gives a the same output, named 'iSense'.
Would it be ok to eliminate it ?
