Author Topic: ETCHANT Question  (Read 21435 times)
Offline innkeeperTopic starter
ETCHANT Question
« on: July 24, 2018, 12:55:01 am »
OK its been years, ok maybe decades since I etched my own PC boards.. last time I did it I used ferric chloride and either those radioshack transfers or a sharpie.
so now I plan to move on to laser transfer as it just seems like a good method. but. now the real question is what etchant.
Radio Shack being closed, I can't exactly run around the corner and buy etchant so i will need to either order some or make my own.
also, my recollection of ferric chloride were not exactly the best experiences, where it stains anything it gets on if its accidentally spilled...basically so if there are better options I am open.
My need to etch will be occasional at best, but likely when I do etch it will be a few in a row.
what are the recommendations for etchant, I see a lot of options out there on eBay, some of which i can't even find info on..
also, I've read about some DIY formulas using muriatic (hcl) acid and hydrogen peroxide.
also seems various formulas are available in liquid and powder.  it would be great if I could store used etchant for reuse later for extended periods of time., but not a deal killer if it is not the best option.
so I am looking for advice from others that do this more than me.  I'm sure there are things I haven't thought of. So please fill me in.
Thanks
« Last Edit: July 24, 2018, 05:56:45 pm by innkeeper »
Hobbyist and a retired engineer and possibly a test equipment addict, though, searching for the equipment to test for that.
Offline Fred27
    • Fred's blog
Re: ECHANT Question
« Reply #1 on: July 24, 2018, 08:52:02 am »
Ferric chloride is still the best etchant in my opinion. A lot of people will say to use HCl and peroxide instead but that is far nastier. It may not stain things, but the fumes can cause all your expensive tools to rust.
Of course, if you just need some boards (rather than enjoying the process of making then yourself) then getting PCBs made is always getting cheaper.
Offline wraper
  • Country: lv
Re: ECHANT Question
« Reply #2 on: July 24, 2018, 09:45:03 am »
Ferric chloride causes rust as well.
Offline Siwastaja
Re: ECHANT Question
« Reply #3 on: July 24, 2018, 09:48:12 am »
If you are going to etch regularly, consider cupric chloride:
http://jimlaurwilliams.org/projects/seychellePaper/index.html
In a nutshell, this starts with your typical HCl+H2O2 method, but instead of throwing it away, you just keep accumulating the "waste", and the "waste" itself slowly starts becoming useful! You add less and less H2O2, until the cupric chloride concentration in your solution is high enough to work on its own, and no H2O2 is needed anymore. What's left is adding a tiny little bit of HCl every now and then; the consumption is down to maybe 1/20 to 1/50 what it is on a single-use HCl+H2O2 method.
You still need to consider the fume handling.
Strong bubbling is very much recommended - not only to speed up etching, and not only for the self-regeneration process; but also to increase the etching resolution.
In H2O2 single use non-bubbled quick etching, I always found practical line width limit at around 10 mils on 1oz clad, whereas a strongly bubbled bath can do 8 mils on 1oz clad very easily and robustly, and 6 mils on 0.5oz.
Strong bubbling, though, generates even more acid mist, so I'd do it outdoors or design a proper fume hood.
We have used this process since... 2012? .. in a club enviroment where a lot of PCBs get done. About a litre of HCl needs to be added only about once a year, which is great because someone needs to get the acid and maintain the process, and this is the only process that runs almost unmaintained! At some point, no one added any HCl for about two years, and the process slowed down from the usual 12 minutes to about 25 minutes, but was still usable.
We built our tank out of PVC (by gluing, using specific PVC glue designed to build tanks), which holds about 6-8 liters of etchant, with a big bubbler on the bottom (also made of PVC sheets, with small holes drilled all over). We run the bubbler out of compressed air line through a pressure regulator valve. The PCB is held in the lid construction: the lid has a piece of PVC sheet with a bit-less-than 1.6mm gap in it; the PCB sits firmly in the gap, and is held vertically. (Air bubbling tries to force the PCB one way or another, so mounting it firmly is important.)
« Last Edit: July 24, 2018, 09:55:42 am by Siwastaja »
The following users thanked this post: 3roomlab, m98
Offline HB9EVI
Re: ECHANT Question
« Reply #4 on: July 24, 2018, 09:48:33 am »
what about sodium persulfate? not only it doesn't have the nasty sideeffects of ferric chloride, it also has better etching properties.
Offline Conrad Hoffman
    • The Messy Basement
Re: ECHANT Question
« Reply #5 on: July 24, 2018, 11:40:22 am »
I've used ammonium persulfate and it's very clean working and IMO better than ferric chloride.
Online sleemanj
  • Professional tightwad.
Re: ECHANT Question
« Reply #6 on: July 24, 2018, 12:03:04 pm »
For convenience I think nothing much beats out HCl+H2O2 (or the resulting cupric chloride after a bit of copper is in the mix), HCl is fairly easily obtained I think in most places from hardware stores, pool supplies, or concrete places (under the names HCl, Muriatic or occasionally "Spirits of Salts"), and H2O2 can be found in some way or another, in the US you can of course get 3% in bulk easily I think, stronger probably online, or hair developer is not uncommon if you really get stuck.
Just don't store your HCl / CuCl2 in an open container around your steel tools is all, and don't mix it up so it's so aggressive, you don't need the acid to be fuming, and it shouldn't be going off like Vesuvius when etching, with 3% peroxide that's not too likely of course, but if you use 30% like I do, a little goes a long way.  As above I don't throw it away, just reuse it, add a cap of peroxide every time I break it out and some HCl now and then in a  pretty haphazard manner.
Ferric, if you can get it, is ok, but so messy and really does like to be warm.
I think the "blue green" etchant sold by China is one of the persulfates, they don't stain like Ferric and you can watch the process going on, but they do need heating and have a limited life.  I see there is only one Aliexpress seller of it oddly, have never bought it intentionally but I think I do have a bag around here that some China vendor threw in as a freebie without telling me... thankfully customs didn't seem to notice the bag of white powder with Chinese writing on it since the package wasn't even opened.
Offline madires
  • A qualified hobbyist ;)
Re: ECHANT Question
« Reply #7 on: July 24, 2018, 12:05:38 pm »
And it should be heated up to 45°C for best performance.
Offline KL27x
Re: ETCHANT Question
« Reply #8 on: July 24, 2018, 05:35:14 pm »
I use cupric. You need a bubbler/aeration or high concentration peroxide to use it efficiently.
I suggest if you can't source cheap, high concentration H2O2, don't expect to reuse muriatic and peroxide over and over. If all you have is 3% from the drugstore, you will overdilute the acid and your etchant is not reusable. It will never turn into cupric chloride. (Once mixed, the H2O2 breaks down spontaneously, releasing O2 into the atmosphere. This means you are diluting the acid with a lot of water every time you add 3% peroxide. Use it within an hour or two of mixing it or you lose it). With 3% peroxide, you would have to be very careful to mix up only as much as needed to barely etch your board, then you might end up with high enough concentration to eventual turn into usable cupric. But it will be a crap shoot.
If you want to use cupric (and you don't have 30% peroxide), it's better to saturate with as much copper as possible the first time you mix the muriatic and peroxide. All you need is a few feet of power cord  off some broken lamp or tool per liter. Drop it in your freshly mixed muriatic and peroxide with a bubbler. Let it run for several hours or overnight. It has enough copper when it turns dark, opaque green like pureed spinach. Then when fully oxidized, it will turn bright green. You can't add too much copper. So you can just put the whole cord in there and remove what's leftover. Then when you use it, just add a little acid and water to dilute it down. (Which you periodically have to do, as maintenance). It's really not that hard or exacting.
« Last Edit: July 24, 2018, 06:15:57 pm by KL27x »
« Reply #9 on: July 24, 2018, 05:53:47 pm »
lots of good info.
the cupric chloride method sounds interesting...and relatively cheap to try, though requires a bit more maintenance and knowledge than just using a throwaway etchant.
I might give that a go to learn about the process.
Offline KL27x
« Reply #10 on: July 24, 2018, 06:09:48 pm »
If you ever end up back to ferric, reusing ferric over and over is possible. When it stops working, dilute it with about 1/3 33% muriatic to water AND add aeration or high concentration peroxide. This is because the by product of ferric is cupric chloride. It will stain like ferric for near infinity and beyond, though. So if you like it, you will eventually mix up some pure cupric.
Offline Siwastaja
« Reply #11 on: July 24, 2018, 06:32:18 pm »
lots of good info.
Nope, it requires much less - almost no - maintenance. The process is so robust against variations that you don't need much control at all.
Throwaway HCl+H2O2 is more tricky to get right and actually requires measuring all three liquids (including water) to get it right. We often saw people being too lazy get totally unpredictable results - such as destructive 30-second etching volcono, or etching that never seems to finish, until you pour in some more H2O2, get a bit too much and then it's a volcano again... One of the reasons it's so tricky is because it's a single-use, we naturally want to save on chemicals (cost & environmental reasons), and measuring small amounts makes measurement errors more serious, as well as can even cause a situation where one of the reagents runs out before the etching is complete. This happened to me a few times while etching large boards in minimal amount of single-use etchant.
Cupric chloride allows you to work with a tank of several litres. If you do hundred boards per year, expect adding HCl once a year and ditching half of the tank to reduce cupric chloride concentration maybe once or twice a decade. We haven't done that yet after five years of active use, just added acid (and water due to evaporation).
« Last Edit: July 24, 2018, 06:37:47 pm by Siwastaja »
Offline KL27x
« Reply #12 on: July 24, 2018, 06:49:24 pm »
I use a very small vertical tank. About 10" x 7" x 3/4". Even with this, there's not much care involved. I probably have to dilute it every 2-3 6"x9" boards in the minimum, but there's nothing to measure. It's as simple as diluting the stuff when it slows down. If unused, it will be ready to go a year later.
The thing about corrosiveness is true. Ferric and cupric need very little to no free acid to work, properly. They are generally a lot less corrosive than muriatic and peroxide. But when you add a bubbler, it is definitely a problem. While it is common to etch with ferric, indoors, I would not recommend you do this with a cupric bubbler tank.
The other thing with HCl and peroxide that is less well known is that it's a very innaccurate etchant. It is easy to chew up or break traces, and the thicker the copper pour, the worse the problem. It is generally sufficient for up to 1 oz pour of smaller boards. When you try to go larger board or use thicker copper, you start having to pay more attention and actively rotating the board to manage hot and cold spots.
HCl and peroxide also eats up sharpie quite fast. If you use sharpie, even to repair small defect in your resist, ferric or cupric are a lot kinder. I've found you need to apply the sharpie to bright shiny copper for it to hold up in cupric; I pre etch my boards before the transfer, and it works great for the toner transfer. But if I want to add any sharpie anywhere, I have to scrape to bright copper, first. I very rarely would ever have a repair to make in a transfer; I've got that down. But I try to make a board singlel sided if at all possible. Sometimes I need to add just a few fat traces to the bottom, and it is often easier to just add those in with sharpie or tape, rather than align and transfer two sides.
There is a hierarchy of accuracy in etchants, with the basic etchants like persulfide being the best. Then ferric. Then cupric. Pure muriatic and peroxide is many times less accurate than cupric. If you start getting into really fine pitch and tight traces, you cannot achieve the same results with acid peroxide without throwing out a lot of boards and making repairs. This may be difficult to understand. The way I picture it is that HCl and peroxide is able to diffuse into small cracks very quickly and is almost as likely to etch the side of a trace as anywhere else, but more "accurate" etchants need more room to work. It's not that the persulfate doesn't undercut the resist layer at all, it's just that the stars have to line up a little better for this to occur. So unprotected copper will etch away at a much faster rate than the sidewall of the protected copper. I have read the lateral etch rate of persulfate is described as 1:8 (w/e thickness of copper pour they use in this scale, who knows? Probably 1 oz pour?) Ferric 1:5, Cupric 1:4. The more excess free HCl you add to the ferric/cupric the less accurate it gets.
« Last Edit: July 24, 2018, 07:57:06 pm by KL27x »
Offline janoc
« Reply #13 on: July 24, 2018, 07:45:30 pm »
Persulfate is a good etchant but a terrible idea if the goal is to to use it only every once in a while. The solution degrades very quickly and you will be making a fresh batch every time. Gets expensive fast unless you are making a lot of boards at once.
Ferric chloride lasts essentially forever without much maintenance.  Also, ferric chloride does not make things rust, unlike hydrochloric acid! (unless you spill it on something, obviously). If someone has ferric chloride fumes causing corrosion, then do not pour acid in it to regenerate it (or to produce cupric chloride) next time! That's a very common reason why this happens - the hydrochloric acid fumes are the culprit, not the ferric chloride (which normally doesn't release any fumes). I have a bottle of it in my bathroom for 8 years now and nothing has ever corroded. However, when I had a bottle of hydrochloric acid around, with factory original stopper and everything, I had everything metallic nearby starting to corrode in as short time as a few weeks.
Also some ready-made ferric chloride solutions have acid added from the factory, but that is far less concentrated and usually not a problem. If you want to be sure, buy ferric chloride crystals and dissolve it in distilled water yourself.
Apart from the corrosion issues, hydrochloric acid and peroxide are a terrible etchant - undercutting of traces is common because the reaction is so rapid and violent. There is a serious splash hazard if you need to add peroxide during etching - acid should go into water, never water into acid (peroxide is essentially water in this regard). Furthermore, the solution releases horrible fumes while etching - pretty much necessitates working outdoors unless one has a proper fume hood on hand. Also disposal is "fun" because the solution cannot be reused and must be neutralized before disposing of it. Basically the only thing going for this combo is price and availability (any drugstore). Do yourself a favor and skip this thing.
« Last Edit: July 24, 2018, 07:52:30 pm by janoc »
Offline KL27x
« Reply #14 on: July 24, 2018, 07:58:28 pm »
^I wonder, now. Maybe the corrosion is due to the bottle of muriatic I keep by the tank. Any unpainted steel within a few feet is toast. I often used ferric indoors without any problem.
Any rate, if you did want to buy ferric, you can still buy it in most countries very easily. You can do it in two ways.
1. buy "dry" ferric chloride "powder" and mix it with water. I use quotations, because it's super hygroscopic and is a sticky brown staining mess that will be one solid clump after the first time you use it. Try search term "anhydrous ferric chloride," I think. This is an exothermic reaction, so take proper precautions. It is super slow to dissolve until the water gets hot, then it goes really fast... and gets hotter. Don't do it in one of those disposable "red cups." The powder is so hard to work with, I suggest to mix up "all of it" at once, if you can, and just store the liquid ferric chloride in appropriate bottles. Quotes, again, because half of it will be a brown goo stuck to the inside of the bag, lol. It won't go bad until you use it.
2. buy iron oxide, red rust powder. This is harder to source, but they sell it in farm supply stores. It is used to stain concrete, among other things. You mix this with about 10% muriatic acid, and you have instant ferric chloride without the mess.
« Last Edit: July 24, 2018, 08:35:37 pm by KL27x »
Online sleemanj
« Reply #15 on: July 24, 2018, 09:14:17 pm »
A quick google and I see that it's available from local hardware stores (in NZ and AU, Bunnings) cheaply in 1Kg pots as various pigment shades from black through red, given the increasing cost (Black < Marigold < Light Brown < Dark Brown < Red) I'd guess that equates directly to the amount of time in a furnace it takes to make it out of Fe3O4
https://www.bunnings.co.nz/search/products?q=Cemix%20oxide&redirectFrom=Any
The black MSDS states that it is Fe3O4 with 90% Fe2O3
So that might be an easy alternative if H2O2 isn't available in much good concentration (here in NZ, you won't even find bulk 3% in pharmacies like you do in the states, you might get a tiny bottle with 30mL or something, but you can at least buy it online cheaply up to about 30%).
I'll note for any compatriots that Bunnings also sell HCl (about 15% if memory serves), it's next to the meths, turps and such.
« Last Edit: July 24, 2018, 09:15:54 pm by sleemanj »
Online sleemanj
« Reply #16 on: July 24, 2018, 10:18:06 pm »
Why making your own PCB? You can get factory made PCBs from China for $5.
If I need a one-off for testing an idea, a prototype, or a personal project, I could take it from finished gerber to ready to solder in an hour, for a couple dollars in raw materials.
Offline NiHaoMike
    • Facebook Page
« Reply #17 on: July 24, 2018, 11:02:50 pm »
Also, low cost CNC machines can make PCBs easily, my $2500 cheap CNC can do 6mil spacing/width with 0.1mm tips when carefully calibrated. Without calibration, 8mil is doable.
$2500 is hardly low cost for a hobbyist. Maybe compared to the setups AvE and Aussie50 have...
Big Clive has done quite a few PCBs with the well known laser printer resist process.
BTC: 18813fu8LQEdDwH9YLM1ABed3XwCfeSeFi
Offline KL27x
« Reply #18 on: July 25, 2018, 02:07:23 am »
I have a true low cost Sherline CNC. I have never once considered making a PCB with it. If you figure out the process and work out the logistics (I have an outdoor bench where the tank sits, ready to etch 24/7), it's simply too easy to do toner transfer. I do 8 mil all day with my eyes closed. Only reason I can't do 6 with deadnuts reliability is because my printer can't actually make a solid line at 6 mil thickness.* Setup and watch CNC mill a PCB for no gain and to chew through and replace engraving/V bits? To get a board that is all chewed up?
If I had the CNC, first, I'd probably think same as you. There is no really easy path to figuring out toner transfer. There is a lot of info out there which is dated or suboptimal. All of it, really. Never did see info/tutorial which shows the easiest way. Whenever I come across the latest and greatest "easy toner transfer" tutorial I read it and chuckle. Most tutorials are written by people who are excited because they just discovered something new. They don't realize if there's a better way... or if the other stuff they're doing can be improved. I'm guilty of that, too. I did a tutorial, once, and I have learned many improvements since then. If you take ALL the info out there and you try everything, with an open mind and scientific approach, it's all out there. Just not in one tidy place.
I order PCBs every few months. I still do toner transfer every now and again. Esp if the board can be done on a single side (or mostly single side), it's fast and easy, and you can make as few or as many as you want without spending time fiddling with gerber settings required by the cheapo prototype place of the week and zipping them, and going through registration and payment and all that jazz. Some days I just don't want to click through folders or fill out online quote forms etc. Last time I used it, I made up 18 tiny EEPROM board for my PicKit2 programmer. Too many for a prototype bottom dollar special. Too little and simple to bother paying actual money.  Done, v grooved on my tilting router table, ready to populate and snap off, before the parts arrived. Honestly, every time I order a new board, it's a headache making sure I crossed all the t's and dotted all the i's.
*When viewed under the microscope, I will see a microscopic break in the printed 6 mil traces every several inches. So on a small board, there might be 2 or 3 breaks. I don't know if this is due to raster or just slop, because I didn't bother to verify if it is consistent or not; I just know it doesn't work. The etched board will have the same number of microscopic breaks in the traces, but the rest will look great. So I assume they are corresponding.
« Last Edit: July 25, 2018, 09:38:33 pm by KL27x »
« Reply #19 on: July 25, 2018, 02:58:11 am »
If you need quick turnaround time, Advanced PCB offers 24 hrs bare PCB (no silk, no resist) for cheap.
good question..
I do get PCB's made, and get a quick turnaround cheap.
but I am mostly a hobbyist, and don't want to shell out money if i don't have to or its a one-off that you just don't need a professional pcb for..
When your experimenting, and want to do a quick proof of concept. there's nothing like being able to each a PCB, drill it, solder on parts and have it operational in an hour.
no cnc, nothing fancy and nothing expensive.
when your ready to have boards made, then I can go do that.  it basically fills that gap between breadboarding, and PCB manufacturing, or when dealing with some RF circuitry where breadboards just won't do.
« Last Edit: July 25, 2018, 03:00:12 am by innkeeper »
Online sleemanj
« Reply #20 on: July 25, 2018, 09:11:22 am »
It got me curious and it was only $9 NZ so I gave it a try.  The oxide powder was found in the cement ailse at Bunnings (a local NZ and AU hardware store chain), NOT in the paint section (who didn't know what I was talking about).  As previously mentioned HCl is in the paint section, but I already have a bottle of that of course.
I mixed about 1/4 Cup of the powder with 1/4 cup HCl and 1/2 cup water, the resulting liquid was pitch black, and much like Ferric Chloride stains everything, indeed, the powder does a good job of staining everything, if you have ever had to handle printer toner, you know what this is like. The measuring cup is now black, the tray is black...
Anyway, after this a test PCB was added (dry film resist, long cured since this already developed test pcb has been sitting in my drawer for maybe a year never etched) and the tray put into a warm water bath as was my previous experience with ferric chloride, namely gentle rocking and sponge action until the copper was gone.
Before Etching:
Etching proceeded fairly typically, but the pcb is somewhat stained, during etching it is impossible to see anything even if you pull the pcb out it's just a black blackness until you rinse it then it's a slightly less black blackness.
I didn't time it, I suppose 20-30 minutes.
After Etching, Stripped with Acetone:
I think I used way too much iron oxide powder which probably contributed to the problem, I expect that an actual ratio could be determined given the molar weights of the oxide powder and acid etc, but I don't think I'm interested enough to try and resurrect my high school chemistry to figure that.
After the etch was done, I was left with of course a problem of disposal, I elected to dig out my old bottle of used ferric chloride and add it to that, then just rinse out the left over iron oxide... ask no questions and I'll tell no lies on that.
The following users thanked this post: KL27x
Offline KL27x
« Reply #21 on: July 25, 2018, 11:03:20 am »
That was FAST. LOL.
Unless you are etching some super thick copper where accuracy is critical, the exact ratio is not necessary, as you have seen. Just wing it and if it's too dark and/or any noticeable sludge in the bottom, dilute some more.
Then, unless you are paranoid about a very mild amount of corrosive fumes, it is practical to add a little more water n acid on top of that. The first product of the ferric reaction is charged cupric chloride. The charged cupric also etches and produces excess of something else. And a bit o free acid will turn that back to uncharged cupric.. which will very slowly over time reoxidize and etch once again. I probably have a lot of that wrong, but the excess acid and water will make the ferric etch better/longer and it will get used up in the process. Whenever you get sludge, you can add a little more. Then toss it when it's too slow.... or add aeration and use it forever.
The reason it is black is the 10% black rust in there, I reckon you will end up with what is like 10% spent ferric chloride (or 5% or something; w/e the stoichiometry is), but without any copper/cupric in it, yet. And unfortunately, the spent ferric does not recharge with aeration or peroxide. It's just along for the ride.
« Last Edit: July 25, 2018, 11:51:06 am by KL27x »
Offline janoc
« Reply #22 on: July 25, 2018, 02:03:17 pm »
Yep, that's 100% the reason. Hydrochloric acid fumes will escape even what you think is a well closed bottle. Unless the bottle is actually sealed gas-tight you will have problems. Even if you don't smell the acid fumes they are there, there doesn't need to be a high concentration of them to start the corrosion.
Offline CopperCone
  • *knock knock*
« Reply #23 on: July 27, 2018, 07:11:21 pm »
don't forget how much the chinese government likes to steal designs.. good reason to make your own if you are doing prototyping prior to mass production where you can get a market following.
Offline CopperCone
  • *knock knock*
« Reply #24 on: July 27, 2018, 07:15:58 pm »
I add a tad of HCl to my ferric chloride etching solutions.
A recommendation is if you want to store muratic acid but you don't want the corrosion, is to buy the 'green' kind which is diluted some what.. it hardly fumes. The normal 35% one basically pours fumes out of it as soon as you open it.
Its alot kinder to use on cleaning cement and shit too.
