Johanson X2Y has smallest inductance possible and many graphs claiming better EMI performance.
I was leerie of using them due to sole-source (patent), unique PCB footprint and 5-10X the price of vanilla X7R's.
That's the trick -- the inductance is fundamentally limited by the length between pads.
If you assume the ceramic lump is an RF short circuit (which is true for all reasonable chips), length and width are the only remaining degrees of freedom. If you use two pairs of 0603s instead of a single 1206 X2Y, you get the same overall dimensions, and the same performance.
But you're still way ahead on parts cost, plus you have the freedom of placing those four capacitors anywhere.
You can use the trace length inbetween as additional filtering, or the FB (or preferably inductor*) between the caps for really high attenuation (3rd order), or you can position the caps straddling the trace for
even lower stray inductance!*Ferrite beads saturate at low currents: typically around 1/5th the rated current (which is a thermal limit only!). In a power filtering application, there's real advantage to using "inductors". What's the difference? A "ferrite bead" is intended for AC filtering, an "inductor" is intended for DC filtering. And yes -- you can get multilayer chips, that look identical, and have similar inductance (at low frequency), but one stores energy and the other saturates. It's all about materials.
"Wideband chokes" are also quite good, usually the axial ferrite rod kind, or the multi-hole ferrite kind. The latter is ungapped ferrite, but the multi-hole design makes them degrade more gracefully under DC bias, which is nice. Rather large, and maybe not cheap, but nice to have on hand anyway.
In summary, you can always do worse -- of course, you can
always do worse; but X2Y is limited by being one single part, whereas you have the freedom to do better when you have individual parts.
On a related subject:
feedthrough capacitors. If you take an X2Y capacitor and short the end caps together internally, you get this. I don't know that they're any cheaper or more available, but the possible attenuation is even higher than the "two caps straddling a trace" example.
There are also combo bypass-and-ferrite-bead parts, usually in a "feedthrough" style design, some of which are usefully cheap. Ferrite beads being what they are, these aren't the best possible solution -- but they can still take quite the edge off, even under bias. Here's a good selection:
https://www.digikey.com/short/3vcm15Tim
