I'm the lucky owner of an Engineer
PA-09 crimper and I was thinking to buy also the
PA-21 unit, but I discovered that they produce also the
PAD-01 bundle (at the end of page):
PAD-01 can be find at a reasonable price at HobbyKing: about
89€- Have someone of you used the (PAD-11 + PAD-12 + PAD-13) = PAD-01 crimper? If yes, what are you opinions?
- How does PAD-01 compare against PA-09/PA-21 combination?
Any suggestions/comparisons/comments are welcome!
. TIA
_ Elio.
[added later] In general I use a single family of connectors for every project (maybe with different pin counts) so I will not need to change dies every so often.
PA-21:
PA-09:
PAD-01:
PAD-11:
