Author Topic: ESD Safety: Too Conductive?  (Read 5908 times)
Offline iamdarkyoshiTopic starter
« on: May 18, 2017, 10:47:41 pm »
Hello again everyone. My current job at Tesla requires an ESD safe environment (ESD safe gloves, footcovers, and smocks) and the footcovers piss me off at the testing station. I'm usually TOO conductive.
And it doesn't let me through. These footcovers have a carbon filled fabric which goes in my sock and runs under my shoe. But by the looks of it, I have to be within a certain range of values. (It tests from my finger to each foot by the looks of it)
I end up just stepping halfway off the foot pads on the tester, and this usually lets me through.
But is being TOO conductive an issue? Or is the programmer of the machine just dumb?
Offline DBecker
Re: ESD Safety: Too Conductive?
« Reply #1 on: May 18, 2017, 11:15:08 pm »
Being too conductive puts you at a higher risk of a fatal shock.
That's why anti-static wristbands are grounded through a 1 Mohm resistor.
Offline mmagin
« Reply #2 on: May 18, 2017, 11:16:25 pm »
Presumably these foot covers are designed with the assumption they'll come into contact with no bare skin, but in your case they are?
« Reply #3 on: May 18, 2017, 11:20:32 pm »
They have a strap dangling off the end that you are supposed to shove in your sock:
Thats what I thought, but there is no way of adjusting these shoe covers...
Offline mmagin
« Reply #4 on: May 18, 2017, 11:25:37 pm »
That strap should have a 1M ohm resistor in it.  Somebody's started buying defective shoe covers.
« Reply #5 on: May 19, 2017, 01:13:54 am »
They are disposable items (they are mostly to keep our floor clear of outside dirt) so the strap IS the resistor, it has a resistance. But it seems to be too conductive...
Offline mmagin
« Reply #6 on: May 19, 2017, 04:10:24 am »
Ok.  Seems strange that you would be special however.  Maybe nobody else is using them correctly?  Or you're the only one who bothered to care?
Offline Someone
    • send complaints here
« Reply #7 on: May 19, 2017, 05:11:27 am »
It can be a danger depending on the voltages you are exposed to, but these units tend to be configured with a fixed or overly safe default limit. This is a problem when people like you on the extreme end of skin conductivity arrive and if you're not touching any voltages above 12V it should be fine and the limits reassessed (50k ohm, 0.5mA, ergo 25V).
« Reply #8 on: May 19, 2017, 05:28:08 am »
This tester has a gate on it and lets one person through per passing test. I'm sensitive to high temperature (I like it 5-10 degrees colder than anyone else) so I tend to sweat a lot, which increases my skin conductivity drastically.
Offline Gyro
« Reply #9 on: May 19, 2017, 08:44:01 am »
Maybe try tucking the strap into your shoe rather than sock? It sounds as if you may have enough moisture happening in there to get you into the 1Meg range!  :)
Best Regards, Chris
Offline Fungus
« Reply #10 on: May 19, 2017, 01:20:37 pm »
Sweaty feet?
Offline jh15
« Reply #11 on: May 20, 2017, 04:56:29 am »
Ask your group leader, boss, test equipment department. They set this up, should not be your problem.
I had to suddenly set up a plant-wide esd program in '84 or so on time for plant vs vendor esd issues. Static mats wristt straps, chains on focusing wrenches for sensitive ir pin diodes, etc.
I was a bit overwhelmed at first, but many, many production issues of the past on other items went away after setting up.
Even (almost) retired and still playing the field, I keep my esd faraday lab coat and wrist strap on.
From pinballs to (non-profit) broadcast studio equipment, and my hobbies.
I think it is really cool that the car I just bought thinks as much about care in manufacturing in their consumer division as in Spacex.
And I heard it here... amazing, maybe not so, id hard to quit reading this forum.
I always wear a seatbelt in a car, don't like the law though. I hope I won't get arrested for not wearing an esd strap in my lifetime though.
If my tesla crashes, and I didn't have my esd strap on, would I be denied insurance coverage
But then, it looks like as above, not a thing to worry about :)?
Tek 575 curve trcr top shape, Tek 535, Tek 465. Tek 545 Hickok clone, Tesla Model S,  Ohio Scientific c24P SBC, c-64's from club days, Giant electric bicycle, Rigol stuff, Heathkit AR-15's. Heathkit ET- 3400a trainer&interface. Starlink pizza.
« Reply #12 on: May 21, 2017, 04:03:38 am »
Congrats on your new purchase!
