Loading [MathJax]/extensions/Safe.js
Author Topic: ESR meter 200kHz  (Read 29287 times)
Offline tigrTopic starter
  • Country: ua
ESR meter 200kHz
« on: August 12, 2017, 12:09:22 am »
Measurement ESR of capacitors:electrolytics,films,ceramics,polymer.
ESR-0,001-30Ohm
F-200kHz
Ut-100mV
VD1,VD2-1N4007
VD3-VD6-1N5819
C2-2,2uF/63v(film)
R2-0,18Ohm
R5-100k
C3(removed)
T1 1-40/2-200
PA1-0,05-0,1mA
U-5v
« Last Edit: August 16, 2017, 12:12:19 am by tigr »
Offline hugo
Re: ESR meter 200kHz
« Reply #1 on: August 12, 2017, 11:33:44 am »
Hi Tigr,
What is the benefit of using 200kHz instead of the more traditional 100KHz ?
What kind of transformer is T1 " T1 1-40/2-200" ?
R2-0,18 Ohm that is not right to me ...
Thanks
« Last Edit: August 12, 2017, 03:40:50 pm by hugo »
  • Country: ua
« Reply #2 on: August 12, 2017, 07:33:42 pm »
Hi hugo.
This frequency is chosen because the circuit working at this frequency. The transformer can be wound with a wire of 0.1-0.15 mm or use a ready one. The resistor R2 can be used 5-0.05 Ohm.
Transformer from my latest version.Removed from some power supple.The ratio of the windings is 1:40.The wire is 0,3mm.
R5-100k
« Last Edit: August 13, 2017, 08:22:50 am by tigr »
  • Country: ua
« Reply #3 on: August 13, 2017, 04:41:31 pm »
Microammeter. You can use different.
50u-100uA.
« Last Edit: August 13, 2017, 08:58:43 pm by tigr »
  • Country: ua
« Reply #4 on: August 15, 2017, 09:00:41 am »
« Last Edit: August 15, 2017, 12:50:52 pm by tigr »
  • Country: ua
« Reply #5 on: August 17, 2017, 07:39:53 pm »
The main feature of this ESR meter is the search for faulty film capacitors of low capacitance in the circuit.
« Last Edit: August 17, 2017, 07:42:26 pm by tigr »
  • Country: ua
  • Country: ua
« Reply #7 on: August 27, 2017, 08:31:42 pm »
Experimental version for ESR 350kHz for ceramic capacitors.
Transformer from the old Sony TV.
« Last Edit: August 27, 2017, 09:41:09 pm by tigr »
  • Country: ua
« Reply #8 on: August 31, 2017, 10:30:00 pm »
Using Tweezers MAX 253, you can measure esr of capacitors of large capacitance.
Capacitors MKT-15uF.
ESR~0,001Ohm.
« Last Edit: August 31, 2017, 10:57:02 pm by tigr »
Offline b_force
    • One World Concepts
« Reply #9 on: August 31, 2017, 10:59:00 pm »
Hi Tigr,
Thanks
Better sweep a range from a few hertz to a few Mhz to get the total impedance.
Why? To get a better idea how capacitors perform at certain frequencies.
I have seen caps that worked great around 100kHzish, but failed bad if you would go somewhat higher.
  • Country: ua
« Reply #10 on: August 31, 2017, 11:55:03 pm »
More examples of the measurement of ESR for high-capacity film capacitors.
  • Country: ua
« Reply #11 on: September 01, 2017, 06:17:33 pm »
The difference in ESR at these frequencies is minimal.
Offline b_force
« Reply #12 on: September 01, 2017, 08:35:05 pm »
Well, the impedance is clearly different.
Also really depends what kind of capacitor you have.
I have seen (and used) ones that are much worse (also much better)
  • Country: ua
« Reply #13 on: September 01, 2017, 09:28:39 pm »
In datasheets for polymer capacitors, only indicate the ESR at a frequency of 100-300kHz.
  • Country: ua
« Reply #14 on: September 02, 2017, 08:25:27 am »
The quality of the dielectric of film capacitors depends on the ESR. This can be verified by measuring different capacitors of 100nF.
« Last Edit: September 02, 2017, 08:32:41 am by tigr »
  • Country: ua
« Reply #15 on: September 03, 2017, 07:21:58 am »
The inductance of the windings of the transformer is 200 kHz.
  • Country: ua
« Reply #16 on: September 06, 2017, 07:25:08 pm »
Tweezers Max 253 always helps in complex cases of measurements in the circuit.
 The computer power supply. The capacitor is 2200 mkF 10V.
ESR-0,008Ohm.
« Last Edit: September 06, 2017, 07:27:20 pm by tigr »
Offline ocw
« Reply #17 on: September 06, 2017, 08:20:29 pm »
Have I missed the accuracy verification?  All of these numbers are nice but if they are not accurate they are meaningless.
Right now I'm testing an economy Ragu 17B multi-meter that I've just received.  For resistance accuracy verification I'm using 0.01% accuracy resistors that range in value of 10 ohms to 10M ohms.  For resistances below 10 ohm I'm using 0.05 or 0.1% accuracy resistors.
  • Country: ua
« Reply #18 on: September 06, 2017, 08:55:51 pm »
And the resistor 0.001 Ohm 1% is not enough? Something I have not seen anywhere, that this resistor was checked by the ESR meter.
They correctly show the measurement of resistors 0.001 Ohm and 0.01 Ohm.
Resistor 0,001Ohm 1%.
« Last Edit: September 06, 2017, 09:15:53 pm by tigr »
Offline ocw
« Reply #19 on: September 06, 2017, 09:48:59 pm »
That reading looks believable.  Sorry.  I hope that your ESR meters and your 200 kHz tests show the same thing.  Two wire readings of a fraction of an ohm to an analog meter have me wondering though.
  • Country: ua
« Reply #20 on: September 07, 2017, 06:43:53 pm »
« Last Edit: September 07, 2017, 09:52:13 pm by tigr »
Offline The Electrician
« Reply #21 on: September 08, 2017, 03:17:55 am »
I very much doubt that the Epcos 15 uF MKT capacitor shown here could have an ESR as low as .001 ohms.
See the data for this capacitor here: https://en.tdk.eu/inf/20/20/db/fc_2009/B32520_529.pdf
On page 21 we see that the typical ESR for a 15 uF capacitor is about .01 ohms, not .001 ohms.
I have no doubt that your meter can measure .001 ohms for a pure resistor, but not for a real capacitor.
If I correctly read the schematic in post #1, the circuit of your meter has no phase sensitive detector so it is measuring the magnitude of the impedance (|Z|) of a capacitor, not the real part of the impedance which is the ESR.
  • Country: ua
« Reply #22 on: September 08, 2017, 07:06:47 pm »
Everything perfectly measures.
The polymer capacitor OS-CON SVP 820uF/6,3V ESR(max.)-0,012Ohm.
http://uk.farnell.com/panasonic-electronic-components/6svp820m/cap-alu-elec-820uf-6-3v-smd/dp/2354726
Tweezers MAX253.ESR~0,007Ohm.
More accurately.
Tweezers ESR-TIGR.ESR-0,0065Ohm.
« Reply #23 on: September 08, 2017, 08:05:45 pm »
More accurately.
It is entirely possible for a meter than doesn't have a phase sensitive detector to correctly measure the ESR of a capacitor if the capacitor is rather lossy.  This is because at frequencies near the self resonant frequency of the capacitor, the impedance (Z) is essentially the same as the real part (Rs) of the impedance.  This is because the curve of impedance versus frequency has a broad minimum, as shown in your image in post #11.  I explain this here: https://www.eevblog.com/forum/projects/impedance-lcr-esr-meters/msg459262/#msg459262 and in the posts following.
But when measuring a low loss film capacitor, the curve of impedance versus frequency has a sharp minimum like this:
The ESR is equal to the impedance at the very bottom of the sharp impedance versus frequency curve, and if the measurement of your meter is at that frequency, then it will measure the ESR; otherwise, it will measure the impedance which will be larger than the ESR.
So, to summarize, a meter that measures impedance (Z) rather than ESR will do what is wanted if you are measuring lossy capacitors such as electrolytics and if your measuring frequency is around 100 kHz plus or minus a bit, but it may read too high with film capacitors.
« Last Edit: September 08, 2017, 08:15:15 pm by The Electrician »
« Reply #24 on: September 08, 2017, 08:12:41 pm »
How do you answer the objection I raised about the 15 uF MKT capacitor that your meter showed has an ESR of .001 ohms? I said:
"I very much doubt that the Epcos 15 uF MKT capacitor shown here could have an ESR as low as .001 ohms.
On page 21 we see that the typical ESR for a 15 uF capacitor is about .01 ohms, not .001 ohms."
