Author Topic: Feedback distortion, how to analyze, simulate and measure?  (Read 12170 times)
Online KokoriantzTopic starter
  • Country: vn
« on: November 03, 2022, 06:13:57 am »
Half a century ago I encountered first time from the refrain of a pop song by the Turtles Happy Together. At that time, solid state was vs tube was the subject and this refrain sounded distorted by SS amps while no problem with simple tube radios. I found many such music pieces that was also bad with SS amps with most difficult ones, Sing, Sing of Goodman, requiems of Verdi and Mozart.
It has nothing to do with harmonic or IM distortions, as very low THD modern amps do same. What I did notice that the NFB at 20khz has an effect, as above 40db the pop song becomes good and 60db for the requiems.
I post bellow in wav format the refrain, stripped from CD of unknown group.
I simulated the end part of this refrain on Tina with 9 ideal amps each 20db NFB, the result was exactly that of the input. So no transient distortion. I simulated with 3 lm3886 models, also excellent, no slew rate limitation problem. The LM3886 in real world with gain of 26db reproduces the refrain with distortion, but with 180/100 ohm feedback resistors with gain of 2.8, the reproduction of the refrain is very good.
I simulated with Rod Elliott's P3A that I know it can't, on simulator it could with no problem.
What non linear element I can try to simulate this type of distortion?
Offline Whales
    • Halestrom
Re: Feedback distortion, how to analyze, simulate and measure?
« Reply #1 on: November 03, 2022, 07:31:39 am »
So you say the song sounds "correct" when played from a simple tube amp radio but "wrong" when played through a solid state amp (and probably bigger speakers)?
If you want to re-create the distortion of tube amplifiers then try looking up "class A tube transfer curve".  This will be a nonlinear curve, you can approximate it with modern transistors in a class A configuration OR you can implement it in software.
There are audio filter plugins for programs like audacity that try to recreate "old radio" style distortion.  Unfortunately there are many unique flavours of this, so you might not find one that makes it sound like you remember.
You will find that the tube amplifier is only going to be one part of the equation.  Much audio distortion comes from the choice of speaker and cabinet.
Another option is to buy an old tube radio and modify it to take a 3.5mm jack input, then record the output with a microphone.  This new recoding can then be played through any modern audio system with reasonable speakers and give you a reasonably correct rendition of what you want.  Be warned that this can be dangerous -- many old tube radios do not operate on isolated power supplies and some even connect the metal internal chassis to mains voltages!  You will have to find one that is suitable.
When I was young I used to play games on my brother's Dreamcast.  The is very different in my memory compared to what it now sounds like (every time I hear it now I think it sounds completely "wrong").  I think the speakers and acoustic properties of the old family CRT television added quite a lot of distortion, especially on the low end, which dramatically changed how it sounded (and I never knew this was a "distorted" form of the sound).
EDIT: How on earth to I link to youtube without it embedding and replacing my words?   >:(
« Last Edit: November 03, 2022, 07:38:01 am by Whales »
  • Country: vn
« Reply #2 on: November 03, 2022, 08:39:49 am »
You got it all wrong. Tubes have nothing to do in this story. It is due to feedback that these types of music gets distorted. As I said you need more than 40db NFB @20khz to get it right. Or, if the phase shift is lower than 90° lower NFB is needed which is the case with tube amps. Open loop amps or wide band amps as JLH do not have this kind of distortion.
  • Country: vn
Offline TheUnnamedNewbie
  • mmwave RFIC/antenna designer
« Reply #4 on: November 03, 2022, 09:55:53 am »
Ah yes, that 'feedback distortion' that audiophiles keep claiming exist but nobody can demonstrate in waveforms or simulation.
The best part about magic is when it stops being magic and becomes science instead
"There was no road, but the people walked on it, and the road came to be, and the people followed it, for the road took the path of least resistance"
Offline Whales
    • Halestrom
« Reply #5 on: November 03, 2022, 10:32:28 am »
What makes you think NFB creates distortion?  Is it because the output of an audio amp with lots of NFB sounds different to an amp that has no or little NFB?
EDIT: If your negative feedback goes out of phase then it becomes positive feedback, which definitely creates distortion and is well understood, but most equipment is designed to avoid this.  I presume you're not talking about this?
« Last Edit: November 03, 2022, 10:56:16 am by Whales »
  • Country: vn
« Reply #6 on: November 03, 2022, 11:55:40 am »
I can show it. Tomorrow I will wire a LM3886 with 26db gain and record the output with the refrain. You can hear it by yourself if you pass the wav file or the youtube  on post 4 on any standard amplifier, 90% chance it will sound garbage. It is to repeat that the amount of NFB required depends upon the phase shift in high frequencies, that is higher is the NFB better it is.
  • Country: vn
« Reply #7 on: November 03, 2022, 12:06:46 pm »
It is not the NFB that creates the distortion, from experience I think it is the integrator function that needed for stability is the cause. With simulation, I understood that there is a kind of non linearity is involved along the phase shift that the simulator doesn't see it, this is the problem that I am trying to understand. The F3A of R Elliott, does distort in real but not on simulator, what it needs to do?
Offline TimFox
« Reply #8 on: November 03, 2022, 02:01:43 pm »
It was shown long ago by writers such as N Crowhurst that negative feedback (properly applied) reduces overall distortion, but can shift the relative amplitudes of the harmonic spectrum in that distortion that remains.
Some people like the sound of even-order distortion (as made by single-ended amplifiers without feedback), but almost everyone agrees that odd-order distortion is annoying.
As a real audiophile, concert-goer, and record collector, I might suggest that the recording process on those original Turtles' recordings was designed to sound "good" on a teen-ager's radio, not a proper high-fidelity system.
I remember an anecdote in Stereophile magazine (under its original ownership, not the current one) around 1968 where a pop group was recording in a professional studio, told the engineers that they didn't like the resulting sound, and used a previous recording as an example of what they wanted.
The engineers had to remove transistors from their professional Langevin amplifiers to satisfy the request.
Offline CaptDon
  • Country: is
« Reply #9 on: November 03, 2022, 08:35:26 pm »
Do like the I.F. amplifiers in radar. Limit the gain-per-stage and use negative feedback (such as un-bypassed emitter resistor or cathode resistor) in each stage and do away with the 40+Db 'reach-around' feedback. The latency of all the stages doesn't change within the usable frequency design range. The phase shift from input to output may appear to change when looking at in vs. out but all signals arrive with the same delay and no reach-around negative feedback distortion or anti-distortion is introduced when the reach-around is no longer needed or incorporated.
« Last Edit: November 03, 2022, 08:39:57 pm by CaptDon »
  • Country: vn
« Reply #10 on: November 03, 2022, 09:51:32 pm »
Sing,Sing,Sing of B Goodman origina.
Turtles remastered
 https://youtu.be/pSw8an1u3rc?t=40
The short refrain file I posted is a recent recording from an unknown group but it is not mp3, as many accuse to be reason why it sounds distorted. The Sing, Sing, Sing  sounds bad because according to a sound engineer, it was recorded with 1940's technology, make it mp3 and you get garbage sound. No, if your amp has wide bandwidth in open loop or feedbackless SET, sounds no any distortion. With multiple horn instruments, a very pleasant beat occurs, you can hear from a marching band or simple three horn, trombone + saxo + trumpet, this pleasant beat I never heard it reproduced in any HIFI. If the amp has feedback distortion, the beat becomes dirty sound as you can hear from this 27 horns music of Goodmans orchestra.
« Last Edit: November 03, 2022, 09:54:51 pm by Kokoriantz »
Offline uer166
« Reply #11 on: November 04, 2022, 12:07:20 am »
I've done some mixed signal and analog work, and have never heard of this. Info on the exact source and definition online seems to be largely "but it sounds worse". Is there some kind of Bode plot or THD measurement or anything at all that shows what people mean by "negative feedback distortion"? Everything is sine waves so it should be easy to measure.
In general, a transfer function with negative feeback can always be converted to a transfer function without any feedback (become open loop, see attached), so the term itself seems to be either meaningless or at least misleading.
  • Country: vn
« Reply #12 on: November 04, 2022, 08:44:38 am »
I recorded the total "Happy together" and the requiem of Verdi.
To avoid copyright problems I introduced errors on the original at the beginning.
The recordings are mono right channel.
  • Country: vn
« Reply #13 on: November 04, 2022, 08:46:51 am »
Recording requiem of Verdi with lm3886 26db gain
  • Country: vn
« Reply #14 on: November 04, 2022, 09:06:08 am »
Happy together original mp3
  • Country: vn
« Reply #15 on: November 04, 2022, 09:07:41 am »
recording with lm3886 gain 20.8
Offline jasonRF
« Reply #16 on: November 05, 2022, 12:28:38 am »
Unless I am missing something, 40 dB at 20 kHz means an NE5532 (10 MHz GBW) can be used with a gain of 5 and still produce “good” audio in your opinion.  Yes?
Can you be specific about the specs required for a “wideband” amp that does not suffer from this distortion that you cannot measure?
Jason
  • Country: vn
« Reply #17 on: November 05, 2022, 02:27:02 am »
I think NE5532 is 60db@20khz. For perfect sound it can provide 0db gain. With NE5534 stable with gain of 3 has 70db, that is good to 10db gain. The same for lme49720 and lm4562.
There are a few 10khz bandwidth opamps, my favorite is AD826, the great CFA AD8008 has bandwidth of 100khz with 1k input impedance for unity gain stable, but cost 18$. https://www.analog.com/media/en/technical-documentation/data-sheets/ad8007_8008.pdf
Offline jonpaul
  • Analog, magnetics, Pwr high voltage, Audio, Cinema
    • IEEE Spectrum
« Reply #18 on: November 05, 2022, 06:35:41 am »
Bonjour a tous!
I have Just noticed this interesting but Very old topic.
Since 1970s in numerous AES papers and other industry/mfg app notes.
eg AES papers
TIM: Otala and John Curl: https://www.ka-electronics.com/images/pdf/Leinonen_Otala_Curl_TIM_Measurement.pdf
SID: Slewing induced distortion   Craig TODD (CTO/VP/RD Dolby Labs) Walt JUNG (audio/analog EE, author) for instance.
https://en.wikipedia.org/wiki/Slew-induced_distortion
Also  Bob Adams at ADI and the usual gang at LT, Nationals Semi etc.
Golden standard of audio measurement  is the fine Audio Precision machines, from Rich Cabot and Bruce Hoffer ex TEK and AP founders.
https://www.ap.com/
Many papers on every aspect of audio measurement and distortion.
We used AP SYS 1 and SYS 2 since 1980s..1990s.
Hope this is interesting to some!
Bon Weekend!
Jon
« Last Edit: November 05, 2022, 07:36:25 am by jonpaul »
The Internet Dinosaur..
passionate about analog electronics since 1950s
  • Country: vn
« Reply #19 on: November 05, 2022, 10:01:18 am »
Salue Jean Paul.
Thank you for information.  This type of distortion by experience is due to phase shift and NFB. The slew rate distortion is independent from NFB.
This type of distortion is independent from the signal level, but it occurs only when great number of voices is involved, as large jazz orchestras or chorals. It is the beat that is provoking some kind of distortion. There is a measurement using multi tones, I will try using very narrow spaced 16 notes in 1khz-3khz range and hear in real what I get.
Offline jonpaul
    • IEEE Spectrum
« Reply #20 on: November 05, 2022, 02:08:20 pm »
Bon samedi cher Monsieur Kokoriantz:
The best test of distortion is two tone  eg CCIR or SMPTE:
Your analyzer or gen generates two tones closely spaced in freg eg CCIR 10kHz and 10.4 kHz. equal level
Intermod will then give sum and difference.
SMPTE IM  is a 6 kHz modulated by 60 Hz   4:1 level difference.
Read the lowpass filtered  difference tone eg 400 Hz CCIR or 60 Hz SMPTE.
VERY sensitive and more relevant test  than THD
AP and other audio analyzers may have an IM tone or option.
IM test  relation to feedback is not clear to me.
I defer to Black, Nyquist, Blackman and the others at BTL that developed feedback theory in 1920s for long lines telephone transmission.
 listening tests require fine program materials
Recommend:
Hig res Beethovens 9th
Solo piano sonatas
Folk music of the Andes
Opera/Jazz/etc with high res recording.
Philips, Sonly and others produced test CDs in 1980s to check CD payers and recorders.
The AV Forums have many test DVD/BR for home cinema, with excellent audio tests.
We used the EBU SQAM Subjective Quality Assessment Material, was avail from EBU decades ago, now rare.
DL a FLAC version here
https://tech.ebu.ch/publications/sqamcd
SQAM has many test tones, sweeps, noise, and very carefully recorded music, including  voice and solo instruments.
SQAM is a REALLY great test of your system, speakers, ears.
Finally beware of auditory "recruitment" when certain tones and levels excite inner ear distortion, especially as one ages the effect can be worse.
Happy listening,
Bon Weekend
Jon
from a feedback free and ancient audio guy....
and a random double blind ABX tyoe relay box, from 1970s..1980s.
  • Country: vn
« Reply #21 on: November 06, 2022, 03:56:36 am »
I formulated a 13 tone generator of 1khz spaced +/-3% or flat to sharp  with 5hz interval.
I applied it on example amp in LTspice and here is the input and output spectrums. This way of measuring 1khz chorus  subtracting from the output, the difference can tell me someting. Of course it is both harmonic and modulation distortions, may be I can see as Jonpaul suggest it can be intermodulation distortion emphasized by integrator.
The distortion of this amp with same input level but single 1khz is 0.07%
« Last Edit: November 06, 2022, 04:02:48 am by Kokoriantz »
Offline jonpaul
    • IEEE Spectrum
« Reply #22 on: November 06, 2022, 06:20:30 am »
no Simulator is accurate for audio.
Just  build it, apply two tones ( not 12) and listen, as you sweep in amplitude and frequency
j
j
  • Country: vn
« Reply #23 on: November 06, 2022, 07:03:57 am »
I posted on 12&13 the original and recorded requiem of Verdi to show the difference, no one listened to it. I am listening such distortions since 5 decades.
Bellow is the multitone 1khz of the LTspice example amp and AD824 which has 40db@20khz in open loop with a gain of 26db.
  • Country: vn
« Reply #24 on: November 06, 2022, 09:22:32 am »
Here is the evidence of IM due to feedback integrator.
The circuit on bench is AD844.
https://www.analog.com/media/en/technical-documentation/data-sheets/AD844.pdf
This CFA opamp has an independent trans impedance followed by a diamond unity gain, the output of the trans impedance is available as Tz. If a capacitor is grounded, it will decrease its bandwidth, if resistor is grounded, it will decrease the gain and enlarge the bandwidth.
First I tested it with 330pF to get 70db open loop gain at 1khz. Then with 600kohm to have 70db gain flat to 60khz-3db. The last is 300kohm to get 64db to 100khz.
It is evident that the IM distortion is lower with wide bandwidth even with lower gain.
