Author Topic: Flame Detection Using Ionization Method.  (Read 3532 times)
Offline virgo_lTopic starter
« on: June 17, 2012, 02:53:57 pm »
I want to detect a flame in a gaz burner using the flame ionization method.
There seems to be very less information about this on Internet on how to implemetn it practically.
I got to know working principe for the method here http://articles.jimtrade.com/1/20.htm
There are various Flame Ionization Detector (FID ) sensors available but they cost a bomb and are used for Gas chromatography.  For my application I don't want to do any kind of Gas Chromotography , I just want to know the presence/absence of flame. I tried other optical techniques ( using photodiode/light sensor ) but they are not that useful and the sensor is becoming hot. As the device has to be small and I can't put the sensor far away.
So if anyone here has idea please advice.
Re: Flame Detection Using Ionization Method.
« Reply #1 on: June 17, 2012, 03:36:11 pm »
Use a spark plug?  Or use an ignitor probe for a furnace in the flame, and detect the current flow from the probe to the jet body.
Offline abbtech
    • Alan's Electronic Projects
« Reply #2 on: June 20, 2012, 09:11:50 am »
Hi Vergo,
Many moons ago I used to install and service DetTronics flame detection systems. They are quite expensive but I am sure you could find a used one on eBay from time to time for a reasonable price.
http://www.detronics.com
As an alternative I am thinking that with some effort you could build a simple version of the system which basically looks for the frequency of the flickering flame in the IR spectrum.
http://www.desusystems.com/files/documents/FREQUENTLY%20ASKED%20QUESTIONS%20ABOUT%20FLAME%20DETECTION.pdf
Personal projects http://alan-parekh.com
Other cool project ideas http://hackedgadgets.com
Offline amyk
« Reply #3 on: June 21, 2012, 08:29:50 am »
Then why not use a thermocouple?
Offline dda
« Reply #4 on: June 22, 2012, 05:17:20 am »
Thermocouples would be easy but might be a little slow to respond. A CO2sensor could be put inline with exhaust gases.
