Author Topic: Flat "DIP IC" pins for PCB-based IC?  (Read 7172 times)
Offline visrealmTopic starter
  • Aussie software guy and electronics enthusiast
    • GitHub
« on: October 10, 2024, 12:19:45 am »
Hi all,
I'm wondering if there is anywhere you can purchase DIP-IC-like pins for a PCB-based project which is designed to replace a retro IC?
I build these replacement RP2040-based TMS9918 VDPs:
...and currently I'm using turned pin headers which work fine, but would be great if you could buy flat IC pins instead.
I've searched to no avail. Any ideas?
Cheers
Troy
Offline Alex Eisenhut
  • Place text here.
Re: Flat "DIP IC" pins for PCB-based IC?
« Reply #1 on: October 10, 2024, 12:59:32 am »
Yes, you absolutely can, that question pops up regularly, I have them on my desk, and every. single. time. I forget what they're called.
Except tonight, I guess.
http://www.dasarodesigns.com/product/batten-and-allen-ba3760-dill-leadframe-dip-pcb-edge-clip-pins/
(DIL, not dill, although that sounds delicious)
Just google "lead frame dil edge pins" and take it from there.
The following users thanked this post: edavid, PCB.Wiz, visrealm, kevinjcell
Offline PCB.Wiz
« Reply #2 on: October 10, 2024, 01:59:43 am »
For this problem in the past, we've used 'sacrificial' standard DIP sockets as 'converters' from headers to flat pins, that can go into standard IC sockets.
They also help protect the fragile turned pin headers.
The following users thanked this post: visrealm
    • GitHub
« Reply #3 on: October 10, 2024, 02:41:07 am »
Thanks Alex and PCB.Wiz.
I found some similar at Digikey. It seems "Leadframe" is keyword.
I like the socket idea too, but it increases the stack height a bit which might be a problem for some.
  • Place text here.
« Reply #4 on: October 10, 2024, 03:40:09 am »
Careful, that's a SIL, like how SIPP memory modules were.
https://en.wikipedia.org/wiki/SIPP_memory
Might be useful if you're trying to make a Commodore 1541 hybrid module.
    • GitHub
« Reply #5 on: October 10, 2024, 05:08:46 am »
Right you are. I could see it working, but it would be a bit... weird. Thanks.
Offline jonpaul
  • Analog, magnetics, Pwr high voltage, Audio, Cinema
    • IEEE Spectrum
« Reply #6 on: October 10, 2024, 05:51:43 am »
The Internet Dinosaur..
passionate about analog electronics since 1950s
The following users thanked this post: pardo-bsso
Online ebastler
« Reply #7 on: October 10, 2024, 06:57:37 am »
Samtech
https://www.samtec.com/flex-stacking/
Those all seem to be big fat square pins which will widen/damage IC sockets when inserted?
Online ebastler
« Reply #8 on: October 10, 2024, 07:03:42 am »
Those pins which sit on the edge of the PCB are the "industrial" solution, I guess. But they won't allow you to sneak a trace or two inbetween the pins and the board edge -- neither on the top or bottom of the PCB. The design the OP shows does seem to use such traces in its routing. (On the other hand they should work nicely for multilayer PCBs, not blocking any real estate on the inner layers.)
There used to be a neat solution called "Flip Pins" -- individual flat pins stamped from sheet metal, held in plastic strips for easy assembly. I have used them in a few projects, but believe the guy who made them has discontinued this product. Not sure whether they are still available somewhere; this page has a description and a few links as starting points: http://oshchip.org/products/Flip-Pins_Product
  • Place text here.
« Reply #9 on: October 10, 2024, 10:23:52 pm »
Not at all, people don't realize SMT came before DIP packages... You can make these:
https://en.wikipedia.org/wiki/Flatpack_(electronics)#
BTW I don't really know what you're building but I commend you on taking the time to look into this solution. It's neater, and "correct", and obviously meant to work with DIP sockets. I see too many DIP-pluggable things with .100 header strips and it hurts my little nerd heart every time I see that.
The only annoying thing is, and it's a big one, is you need to trim these pins somehow. I don't think there are any ready-made DIP lead slicers out there that could fit on a kitchen counter either.
Very interesting.
« Last Edit: October 10, 2024, 11:23:29 pm by Alex Eisenhut »
Online Benta
« Reply #10 on: October 10, 2024, 11:06:22 pm »
I think these are what you're looking for:
https://www.te.com/en/plp/leadframes/Y30nn.html?n=42057&d=544927
They need to be cut after mounting.
« Last Edit: October 10, 2024, 11:09:46 pm by Benta »
The following users thanked this post: edavid, visrealm
Offline dorkshoei
« Reply #11 on: December 10, 2024, 05:51:28 pm »
The issue with the the BA leadframes is the huge MOQ.   There doesn't seem to be a distributor who will sell off the reel.   This discussion on Parallax Forum has been posted here before and is informative.   The poster went on to design the "flip pins".
A standard IC leg protrudes about 4mm below the base of the device but the BA3760 (which fit a standard pcb thickness) are about 13.7mm so they need accurate hand trimming.   A pcb using them will probably also sit slightly higher in a socket than a true IC because the 2mm standoff of the leadframe extends below the pcb.
I don't think these are an option.   The only ones that supports a standard pc board thickness (1.57mm) are a horizontal attachment.    The Dual In Line only supports 0.63mm and 1mm pcb thicknesses.
AFAIK the BA3760 (there are several threads here on them if you search) is about the best option assuming you can find some at a decent price.
« Last Edit: December 10, 2024, 06:12:19 pm by dorkshoei »
The following users thanked this post: grantb5
Offline grantb5
« Reply #12 on: August 07, 2025, 01:00:36 am »
Offline amyk
Offline salfter
    • My Blog
« Reply #14 on: February 27, 2026, 11:24:58 pm »
Comparing the dimensions in the provided image to what I could find on a datasheet, I think these are Batten & Allen BA3502 pins for a 1.0-mm PCB:
https://www.reactivemicro.com/product/lead-frame-pins/
Datasheet: https://www.batten-allen.com/hubfs/Downloads/DIL-F-Type-2021.pdf (go to page 2)
If I had to guess, the exact part number would be BA3502-TGBP-4A (or -1A...can't tell for sure). These might actually be available in small quantities (20, 40, or 100) at moderate prices instead of having to buy a whole reel of 50k pins.
"Flip pins" have been discontinued everywhere they were sold.  I found some pins from TE on DigiKey, but you're back to ginormous MOQs again: over 1M if you order through DigiKey (at a cost approaching $19K) or 33k for about $568 from a marketplace seller:
https://www.digikey.com/en/products/detail/te-connectivity-amp-connectors/1544169-1/2305328
« Last Edit: February 27, 2026, 11:33:35 pm by salfter »
The following users thanked this post: oPossum
Offline grantb5
« Reply #15 on: February 28, 2026, 01:40:39 am »
The turned/machined headers are OK, but I find the ones in the pico9918 photo to be too thick. Depending on the style, I would flip them and put the smaller diameter pin toward the receiving PCB/socket.  They take up a few mm of vertical height too which can be problematic.
These days I just use the flat pin headers that you see on the Arduino compatible hardware, though I source mine from Samtec at about $5 USD per 28 pin DIP. I can look for a part number. In my case I push them through the board I make then solder and clip off the plastic header. This emulates a DIP part pretty well, but it is a PITA to do.
Offline Kipling
« Reply #16 on: October 04, 2026, 02:27:16 pm »
Late to the party here, but I have a solution, which mimics the unobtaniuum "flip pin" theme.
I bought a load of these from Digi-Key (also available from Mouser); they are available in any quantity.  https://www.digikey.co.uk/en/products/detail/te-connectivity-amp-connectors/1544210-2/4731536
Whilst they would work OK if you designed your board to be a smidge under 0.3" wide (or whatever width IC socket you intend to use as a receptacle) and you don't need to take any tracks between the through-hole mounting for the bent pin and the board edge, or if the through-holes would leave insufficient space for components in-between, then you can modify these pins so the centre-line of the pin is directly in line with the through hole and not the board edge.
For this, trim the straight pins (those that would normally be flush to the board edge) as far back as you can, then flatten out the bent pin.
The pins themselves are 0.5mm wide and 0.3mm thick and are reasonably soft. The through hole size I recommend is 0.65mm ID and pad size 1.65mm OD.
You can then solder them in and trim the pin length to suit.
Hope these photos explain what I've done.
« Last Edit: October 04, 2026, 03:58:34 pm by Kipling »
The following users thanked this post: oPossum, edavid, ebastler
Offline grantb5
« Reply #17 on: October 05, 2026, 01:54:16 pm »
For my own case, I find those too thick and they bend too easy. I need something that will tolerate insertion and removal several times at minimum and won't ruin a standard dual wiping DIP socket. 4uConn makes the best part I've found so far and they are available in many places such as
36-pin Stacking header - pack of 5!
https://www.adafruit.com/product/3366
I make my PCB wide enough that these are soldered into through-holes on my board, then cut the tops off.
Offline bkw
« Reply #18 on: October 29, 2026, 04:47:20 am »
So far I found 3 ways. None convenient.
https://gist.github.com/bkw777/52d85d89eeff8445cc667685d05ea94d
The SIL Leadframe method is probably the most repeatable and practical for production, but I mostly do the plain gold plated brass wire method since it's the most efficient in materials. It's just plain wire, and you don't waste a single mm of it. But it's only good for on-off self/hobby stuff. I would hate to have to make a batch of 100 boards!
Offline Cathy
  • Country: hk
    • Lisleapex Electronic CO., LTD.
« Reply #19 on: October 29, 2026, 06:26:23 am »
Spot on regarding the mechanical clearance headaches. When dropping custom adapter boards into vintage sockets, managing the stack height is always a tightrope walk—especially if you're routing around legacy glue logic or standard support ICs like the MC74HCT86ADR2G https://www.digikey.co.uk/en/products/detail/onsemi/MC74HCT86ADR2G/2305576 XOR gates or SRAM upgrades like the AS6C6264-55SCN.https://www.lisleapex.com/product-as6c6264-55scn
The leadframe alignment trick mentioned earlier is definitely the right path for durability, but hand-trimming those pins down evenly without a jig is a real chore. If your routing allows it, designing the board footprint to accept stamped strip pins makes assembly much cleaner, though you still have to watch out for stretching delicate leaf wipers over time. Great discussion on solving an age-old retro repair bottleneck!
Cathy | Tech Engineer at Lisleapex Electronic Happy to help with part selection, datasheets, or sourcing questions! www.lisleapex.com
