Author Topic: flyback mosfet problem  (Read 2585 times)
Offline electros6Topic starter
« on: September 11, 2014, 01:10:51 pm »
I tried to design a 48 v to 12v fly back converter using PWM controller. When I connect the transformer and power up the circuit even when the gate to the mosfet is removed the mosfet conduct and short the source.I used 34v dc from a transformer  and rectifier. I tried different voltage mosfet eg IRF840 , IRF540 , IRF44n ctc also ex-bit the same characteristics. can somebody spot out
Offline Marco
Re: flyback mosfet problem
« Reply #1 on: September 11, 2014, 01:24:51 pm »
"even when the gate to the mosfet is removed the mosfet conduct"
You need to short the gate to source to be sure it is off and stays off.
Offline Seekonk
« Reply #2 on: September 11, 2014, 05:18:53 pm »
That is called phantom switching.  Even if you short the gate, a FET will draw power when it is first applied.  This is due to the Miller Effect.  Generally it is not a problem.  In really high power switchers it can be overcome by using a negative bias in the gate.  The "phantom gate voltage" pulse still  happens but it remains too low to turn on the FET.
Offline planet12
« Reply #3 on: September 11, 2014, 10:22:42 pm »
It's very hard to know what's going on without seeing a schematic - can you provide one?
Along with the miller capacitance pulling the gate up, as discussed above, the other option is possible reversal of the drain-source pins, meaning the body diode will conduct - this would also cause the symptoms you're seeing.
