Hello again,
Same question with replies here: https://sourceforge.net/p/freertos/discussion/382005/thread/78ba77df/
Just to say that this is also my doing...
My network is a cluster of motes that may be applied in 2 different scenarios.
- Close range cluster (with a diameter of <500m)
- Wide range cluster (with a diameter of 1 to 5km)
For this I have at my disposition 2 radios being this ones:
- Sub 1GHz - CC1000 (433MHz) - RF
- Over 1GHz - CC2420 (2.4GHz) - 802.15.4 Low-rate WPAN
The mote microcontroller is a MSP430F5x chip and the transmission rate is very low. Packets are sent when there is an event, so the network must be real-time capable.
Do you want a protocol or a device driver, or both?
I need the entire stack library, but mainly the network and transmission layer ones, because the lower ones will need modification (most probably).
I was thinking MAC -> IP -> TCP
The cluster will then use a Gateway Node to send the data over ex. Ethernet to a DataBase.
