Author Topic: FreeRTOS based Wireless Sensor Network Communication Protocols  (Read 4088 times)
Offline Mr.D2Topic starter
« on: September 23, 2014, 03:44:16 am »
Hello!
I am currently making a WSN project that runs FreeRTOS and I am looking for a Communication protocol [modified: library] that can be used alongside the FreeRTOS uOS.
I found some references to some, but they are paid extentions to the FreeRTOS kernel. Being this ones:
- http://nabto.com/
- http://www.freertos.org/FreeRTOS-Plus/embTCP/FreeRTOS_Plus_TCP.shtml
- http://www.freertos.org/FreeRTOS-Plus/FreeRTOS_Plus_UDP/FreeRTOS_Plus_UDP.shtml
Can someone help me with some suggestions or pointers of what can i use?
Comments and replies are welcome!!
Thanks,
         Diogo Guerra
« Last Edit: September 23, 2014, 04:43:16 am by Mr.D2 »
Offline Kremmen
Nothing sings like a kilovolt.
Dr W. Bishop
Offline RichardBarry
+ http://www.FreeRTOS.org + http://www.FreeRTOS.org/plus
The de facto standard, downloaded every 4.2 minutes during 2015.
IoT, Trace, Certification, TCP/IP, FAT FS, Training, and more...
Re: FreeRTOS based Wireless Sensor Network Communication Protocols
« Reply #3 on: September 23, 2014, 05:39:20 pm »
Hello again,
Same question with replies here: https://sourceforge.net/p/freertos/discussion/382005/thread/78ba77df/
Just to say that this is also my doing...
My network is a cluster of motes that may be applied in 2 different scenarios.
- Close range cluster (with a diameter of <500m)
- Wide range cluster (with a diameter of 1 to 5km)
For this I have at my disposition 2 radios being this ones:
- Sub 1GHz - CC1000 (433MHz) - RF
- Over 1GHz - CC2420 (2.4GHz) - 802.15.4 Low-rate WPAN
The mote microcontroller is a MSP430F5x chip and the transmission rate is very low. Packets are sent when there is an event, so the network must be real-time capable.
Do you want a protocol or a device driver, or both?
I need the entire stack library, but mainly the network and transmission layer ones, because the lower ones will need modification (most probably).
I was thinking MAC -> IP -> TCP
The cluster will then use a Gateway Node to send the data over ex. Ethernet to a DataBase.
« Last Edit: September 24, 2014, 02:11:15 am by Mr.D2 »
