Author Topic: FT232RL Loopback FAIL  (Read 9655 times)
Offline tedre191Topic starter
« on: July 17, 2013, 12:10:15 am »
I just receive my pcb from OshPark for my new project and i can't get the ft232rl chip working.
When I plug my board to my computer, drivers are installing and I can see the TX led light up when i'm sending data with Putty.
On a loopback test, RX and TX led light up but I receive only 0x00 values back.
Am I missing something ?
Thanks
Offline bobdagangster
Re: FT232RL Loopback FAIL
« Reply #1 on: July 17, 2013, 12:18:57 am »
Unless I am mistaken, it generally helps to connect the RX/TX pins on the FTDI to the MCU... (Or maybe the net names are invisible in Eagle?)
« Reply #2 on: July 17, 2013, 12:27:33 am »
Sorry, my mistake. Indeed, RX and TX are connected to the MCU TX and RX, names are not visible in that screenshot.
To do my loopback test, I removed the MCU and  connected pin 1 and 5 together. I tried with and without the two 1k resistors.
« Reply #3 on: July 17, 2013, 12:50:23 am »
I was about to suggest that...
CTS might want to be pulled up?
Offline fcb
    • Electron Plus
« Reply #4 on: July 17, 2013, 01:02:46 am »
Download "FT_prog" from the FTDI website, have a look at how things are configured (the FT232R has onboard EEPROM).
It should be trivial to join TX & RX and use something like Hyperterminal to loopback - you may have flow control setup??
« Reply #5 on: July 17, 2013, 01:46:51 am »
I just tried, didn't work.
Flow control is set to "None". I downloaded FT_prog and i'm able to read the FT232R EEPROM content.
None of the options in "Hardware Specific" are enabeled.
I'm probably missing something ..  :(
Offline David_AVD
« Reply #6 on: July 17, 2013, 01:48:29 am »
Did you buy the chip from a known source or eBay / AliExpress?  There are dodgy fakes doing the rounds if I recall correctly.
« Reply #7 on: July 17, 2013, 03:14:24 am »
I bought the chip on eBay (2 of them, both the same issue).
http://www.ebay.ca/itm/140838941057
« Last Edit: July 17, 2013, 03:15:58 am by tedre191 »
Offline richcj10
« Reply #8 on: July 17, 2013, 04:07:15 am »
You got fake chips.
Offline mickpah
    • Yeti Hacks
« Reply #9 on: July 17, 2013, 05:26:07 am »
You got fake chips.
yep very likely, I bought a board from Itead , same issue. They admitted they had been caught with fakes. They replaced it.  The QC sticker must have been for the board only I guess
Offline sleemanj
  • Professional tightwad.
« Reply #10 on: July 17, 2013, 05:39:11 am »
RTS and CTS are active LOW, either pull them down, or link RTS to CTS so it's signalling itself.  Don't know if it will help, but worth a try huh.
Offline David_AVD
« Reply #11 on: July 17, 2013, 06:15:41 am »
No need to do anything with the control lines.  Hooking up tx and rx is all you need for a basic connection.
Offline amyk
« Reply #12 on: July 17, 2013, 10:51:34 am »
You got fake chips.
Or just defective...
« Reply #13 on: July 17, 2013, 01:10:17 pm »
Thanks everybody, I'm gonna buy new chips (from Digikey this time) and give them a try.
« Reply #14 on: July 29, 2013, 05:27:43 pm »
Just received my new chips from Newark and everything is working now. Thank you all for your help !  :D
