Author Topic: Full Size SD Card Extender Push-Push to Insert and Eject the Card  (Read 3062 times)
Offline dellsam34Topic starter
I can't seem to find a link to a full size SD card extender that uses a push-push to insert and eject the SD card, All I can see is regular push-pull style. Any links?
Re: Full Size SD Card Extender Push-Push to Insert and Eject the Card
« Reply #1 on: August 21, 2026, 03:24:05 pm »
No replies tells me such adapter doesn't exist.
Offline coromonadalix
« Reply #2 on: August 22, 2026, 01:13:32 am »
adafruit do have a push push  full sd size ?
https://www.adafruit.com/product/3687
« Last Edit: August 22, 2026, 01:16:38 am by coromonadalix »
« Reply #3 on: August 22, 2026, 07:33:47 am »
This eBay seller confirmed this one is indeed a push-push type, We're getting somewhere.
https://www.ebay.com/itm/397883144976
« Reply #4 on: August 22, 2026, 07:39:53 am »
What I'm trying to do is replace an internal 320GB SATA HDD with a SD card slot because the recorder has only firewire to access the recordings, With SD card I just record into the SD car and transfer the recordings to a modern computer that doesn't have firewire. My next big question is, what kind of SD to SATA adapter should I get for a maximum capacity?
I know for sure they don't make SD to SATA adapters with a ribbon cable soldered to the PCB and the other end is a SD card slot, That would be too custom, I'm fine with the above SD slot extender.
Offline Psi
« Reply #5 on: August 22, 2026, 08:03:35 am »
I've seen laptops with a push in, push out full size SD slot.
« Reply #6 on: August 22, 2026, 08:32:19 am »
What that has to do with this topic?
Offline Psi
« Reply #7 on: August 22, 2026, 09:25:22 am »
sorry, I misread the 'extender' bit.
That will teach me to skim-read stuff
Online xvr
  • Country: ie
    • LinkedIn
« Reply #8 on: August 22, 2026, 12:00:44 pm »
An SD card and SATA are COMPLETELY different things. Firstly, SATA is MUCH faster. The recorder may simply refuse to operate at SD card speeds.
This is also a non-trivial beast. A bunch of wires just isn't enough.
It's much easier to buy a different recorder.
Offline Bud
« Reply #9 on: August 22, 2026, 02:47:03 pm »
DigiKey Part Number
1528-2522-ND
« Reply #10 on: August 22, 2026, 08:20:19 pm »
Nah, it has been done before with no problems, I can't buy another recorder, This is the one that I bought specifically for this task to transfer DV/HDV/DVCPro tapes, Before I do this with a computer that runs Wind7 and firewire port but but it's dying and I have to move to a modern solution, Lets just stay on topic which is the conversion from SATA to SD card.
« Reply #11 on: August 22, 2026, 08:21:42 pm »
DigiKey Part Number
1528-2522-ND
Thank you sir, now we're really talking.
Online SteveThackery
  • 50 year novice
« Reply #12 on: August 23, 2026, 12:09:32 pm »
DigiKey Part Number
1528-2522-ND
Wasn't this already given in Reply #2?
Offline PlainName
« Reply #13 on: August 23, 2026, 02:25:45 pm »
You expect people to drop what they're doing and sort out your problem for you within 7 hours? Would you do the same for everyone else on this forum?
The following users thanked this post: tooki, SteveThackery
« Reply #14 on: August 23, 2026, 07:23:36 pm »
Every thread has whiny little bitches, This is a public forum for anyone seeking the same thing, When information is gathered it becomes public, the more information the better, down the road some links may go dead, Where the hell did I say I need an urgent service? I said I could not find clear information about this type of device, Hence asking here knowledgeable people who use this stuff daily, not the whiny bitches like you.
« Last Edit: August 23, 2026, 07:25:13 pm by dellsam34 »
The following users thanked this post: Analog Kid
Offline amyk
« Reply #15 on: August 23, 2026, 07:47:27 pm »
Anything that supports SDUC, although those are probably still quite rare and SDXC (2TB max) may be all you can find.
« Reply #16 on: August 23, 2026, 08:17:29 pm »
Copy that.
Online NiHaoMike
    • Facebook Page
« Reply #17 on: August 23, 2026, 08:52:37 pm »
Have you considered a SD to SATA adapter that happens to fit where you want the SD slot and extending the SATA connection if needed?
BTC: 18813fu8LQEdDwH9YLM1ABed3XwCfeSeFi
« Reply #18 on: August 23, 2026, 09:12:14 pm »
I have, I figured mounting an SD card slot is a lot easier than mounting a bigger board, Also a ribbon cable is a lot easier to route than a bulky SATA and power cables, But thanks for the thought, It is still potentially considered, I will make that decision when I get the recorder and take it apart.
Offline Kilrah
« Reply #19 on: August 23, 2026, 09:14:26 pm »
When you assumed after 7 hours that no answer = doesn't exist rather than maybe, just maybe that wasn't enough time for people to have looked at it yet, timezones exist, etc...
The following users thanked this post: thm_w, PlainName
  • 50 year novice
« Reply #20 on: August 23, 2026, 10:13:51 pm »
You concluded there was no such adapter because no-one had replied after 7 hours. When someone suggested that was an unreasonably short period, you said:
Every thread has whiny little bitches......
You are rude and a bully. I would be delighted if you fucked off this forum and didn’t come back.
« Reply #21 on: August 23, 2026, 10:59:56 pm »
I would be even more delighted if you haven't shown up here whining about an assumption like a little whore, ruining an entire topic, the likes of yours are just garbage filling up a great forum like this, So fuck off and let knowledgeable people discuss.
« Last Edit: August 23, 2026, 11:03:41 pm by dellsam34 »
« Reply #22 on: August 23, 2026, 11:00:59 pm »
So? The topic is still open, isn't it?
Offline Halcyon
  • Global Moderator
« Reply #23 on: August 24, 2026, 04:47:26 am »
Relax. Everyone is entitled to their comments just as much as you are. I'd suggest your comments above are uncalled for and are also needlessly filling the forum with "garbage". If you have a personal dispute with someone, feel free to take it up with them privately. Everyone else doesn't need to be dragged into it.
« Reply #24 on: August 24, 2026, 07:33:21 am »
They started the insults, not me, I got my answer way before anyone posted, I just kept feeding the thread with information in case someone else bumped into it later on, Thanks for chiming in, feel free to delete all the garbage posts, Lets carry on.
