Author Topic: GPU Overclock  (Read 8257 times)
Offline ChrisGreece52Topic starter
  • Electronics Engineer - Tinkerer - Nerd
GPU Overclock
« on: April 30, 2013, 10:18:47 am »
Hey guys.When i got my pc i asked (and regret that every day of my life) for a home pc (NOT GAMING ... AND I WAS AND AM A BLODDY KID) and it came with a good graphics card (for the time i got it ) but now it lags at most new games..... and i think overclocking the card is the way to go.
Things that you MUST know:
1)At the time (2 years ago) the only thing i new about pc's was the Hard Disk Drive (ONLY)
2)I got an already built pc and did NOT made it my own.
3)The graphics card is a ATI Radeon HD 4600 series.
4)the card has still the fan it came with (80 mm (i believe) 12 volt fan)
5)I am NOT willing to burn my card.
6)I can controll the fan speed if needed with the Speedfan program.
Thank you.
Offline Balaur
Re: GPU Overclock
« Reply #1 on: April 30, 2013, 10:34:47 am »
I don't know if overclocking is worthwhile. Any improvements will be marginal.
You can have a Radeon HD 6670 for around 70 euros. That card seems to be (according to this and this) twice as fast as your HD 4600.
Best regards,
Dan
Re: GPU Overclock
« Reply #2 on: April 30, 2013, 11:24:35 am »
Ok but ... 70 euros...... i am saving money for a new mobile phone ... (XPERIA L) if i can spare some i will buy a new card but i dont know if it is supported by my motherboard ill check and reply.
Offline peps1
  • if you can't open it, you don't own it!
Re: GPU Overclock
« Reply #3 on: April 30, 2013, 11:28:15 am »
before you try over clocking, have you checked you have the most upto date drivers for your GPU?
Personally I would not overclock this card, it just doesn't have the headroom or cooling with that reference cooler to warrant it for the tiny improvement you may get.
I would save up and get a new card that will play the games you want, and has been designed in mind to be over clocked with a non reference cooler.
But if you must (and I think you will) follow this guide!
http://youtu.be/gA_l5-HDel4
Re: GPU Overclock
« Reply #4 on: April 30, 2013, 11:32:45 am »
Hmmmmmm that put me into thoughts ... ill think of it a bit more.
Re: GPU Overclock
« Reply #5 on: April 30, 2013, 11:51:38 am »
Offline peps1
Re: GPU Overclock
« Reply #6 on: April 30, 2013, 12:27:09 pm »
Your Board will take any PCI Express GPU like the 6670 or Radeon HD 7750 (both around 70Euro), and even cheaper second hand!!! maybe ask your friends to see if anyone is upgrading and will let you have there old card.
Offline mariush
Re: GPU Overclock
« Reply #7 on: April 30, 2013, 04:07:17 pm »
There's no point in trying to overclock your 4600 series video card.
Simply put, it's a slow chip with reduced performance, to make the video card cheap.
I'll try to explain it as simple as possible.
AMD wants to make a fast video card processor to put on a video card, so they design one and fabricate it. It is very powerful but they spent a lot of time and money designing it so they need to ask for a big price to recover their investment.
This processor has a lot of mini cores and a lot of features. If your CPU has two or four cores, think of a video card processor to have 500-1000 mini cores that all work at the same time on a part of the picture you see on the screen, when a game runs.
AMD designs this chip to run at a particular frequency and to have a number of mini cores but they know the fabrication process is not perfect.  The factory produces about 300-500 processors at a time on a big round die of silicon that looks like this:
An automated machine then cuts those mini squares which are the actual video card processors and tests each one of them.
Due to how these processors are fabricated, the chips closer to the middle of this round die called wafer are capable of running at higher frequencies and usually come out closer to perfection.
The more you get closer to the edges  of this round die, the processors come out with small defects, such as 10 out 1000 mini cores not working, or the processor overall is not capable of running at the frequency AMD wants the processor to run.
So let's say AMD advertised the next  Radeon 4850 to have 800 mini cores and that it's capable of running at 500 Mhz.
AMD plans ahead and makes the chip with about 840 mini cores, knowing the fabrication process is not perfect and that some will come out broken, so it wants as many chips to have at least 800 mini cores working.
The chips right in the center are tested and come out capable of 700 Mhz and all 800 mini cores working, so AMD puts these chips aside because they may want to use them for a future "premium" video card like 4870.
The chips a bit further from center all manage 550-600 Mhz and have 800 mini cores working so AMD uses these for 4850.
When you go further from the center, the chips only manage 520-550 Mhz  and may have a few mini cores faulty (let's say only 700-750 mini cores work properly) so AMD renames this chip as 4830 and sells this as a chip running at 450Mhz (lower than 520-550 mhz to allow some overclocking) and with 640 cores (less than the 700-750 mini cores tested good)
All the way further from the center, you have 4650 and 4670 chips that have only 320 mini cores working and run at even lower frequencies.
4550 for example has only 80 cores enabled.
This process is called binning. Now, it's not always the case that the chip on your video card is one that had faulty cores, sometimes the fabrication process is so good that almost all chips could be sold as let's say 4850, but there's a high demand for cheaper video cards, so AMD just takes that chip that could be sold as 4850 and disabled some perfectly good mini cores and lowers the frequency and sells this chip as 4650 or 4670.
With these chips, you can overclock them quite a bit, but the thing is you can't tell which kind of chip is on your video card.
Also, even if your chip could be overclocked a lot, the video card doesn't have power circuitry on it good enough to give enough power to the chip to run with such big overclocking.
So anyway, if your video card is from "4600 series" , it's probably 4650 or 4670.
These video cards only have 320 mini-cores so even if you overclock them, games simply expect a bigger number of cores on a video card chip these days and the chip won't keep up.
In addition, the video card manufacturer saved money by using ram on the video card that runs at slower frequency so the game can't "upload" the pictures and game content into the video card fast enough to give you faster graphics. Even if you manage to overclock your video card's chip, it will waste time waiting after the ram chips to give it data to crunch.
Changing the cooler on the video card won't help you, and the performance improvements like I said are so small it's not worth trying to overclock such video card.
Best you can do is to sell this card on eBay for something like 15-25$ , add about 60-80$ and get a newer video card like the Radeon 7750 or something like that.  Anything under about 100$ these days, won't bring enough performance over your current video card to be worth buying.
The processor on a 7750 is simply put smarter and supports more features that games these days expect a video card to have.
Offline Jon86
Re: GPU Overclock
« Reply #8 on: April 30, 2013, 04:18:53 pm »
It might be worth a try, most of the time you can't damage it by overclocking.
MSI Afterburner should work, just take up the core and memory clock up bit by bit as far as it'll go.
Also, push up the voltage a bit if you can.
Sure it might not make much difference, but on my GTX560 I could definitely notice better performance in some games.
Anyway, just give it a go.  :-+
Death, taxes and diode losses.
Re: GPU Overclock
« Reply #9 on: April 30, 2013, 05:02:54 pm »
Got it thank you ... but i dont think ill upgrade just yet.
I will think for an upgrade to the future but for now i dont think so.... because i would prefer to save money to change my motherboard AND my graphics card.
Offline marshallh
    • retroactive
Re: GPU Overclock
« Reply #10 on: April 30, 2013, 06:04:22 pm »
Overclcoking, sure it may work but it is just pissing in the wind. However if you really do want to play around, get MSI Afterburner (yes it works for AMD cards) and very carefully and iteratively start bumping up clocks.
Like others are saying, you will at best squeeze a few more FPS out of your aging card, best upgrade to a used 58xx or 68xx series. They can be had for cheap and they still have a good punch.
Verilog tips
BGA soldering intro
Re: GPU Overclock
« Reply #11 on: April 30, 2013, 11:20:51 pm »
Catalyst Control Center from the cards website has an overclocking option.
