- high audio quality
- digital volume control (encoder + picmicro maybe IR or BT remote)
The issue is not the signal chain. The issue is reasonably powering it (like, not 230V input, and no noisy DC-DC converters), and having a high quality source (AKA: USB DAC)
hi all..
the source will be only RCA analog input with line levels, so I prefer to not convert the signal into digital, process it and then reconvert into analog.
potentially te audio source will be a turntable with a proper preamplifier.
i'm going to look at the component you suggested.. thanks!!!
I'm thinking about my next project and I would build an audiophile headphone amplifier.
http://www.njr.com/MUSES/series/MUSES72320.html
LM1972 is a bit less esoteric.
If power supply current is not a factor, and you want an excellent digital volume, class A headphone amp with a bit of kick, I would use the MUSES, powered at full 30v (+/-15v), have the output drive 2 x 30v ultra logic level (1.2-1.8v) mosfet gate directly operating in voltage follower mode
All that engineering spend on linearity, thrown away. Not that it matters.
That's why I asked what the source is.
If it's USB then you can get a complete headphone DAC for under $10 on eBay.
eg. http://www.ebay.com/itm/281827865856 (randomly chosen seller)
Chipset is this: http://www.ti.com/lit/ds/symlink/pcm2704.pdf
If you want 'audiophile' capacitors it's a couple of bucks extra.
And if you don't trust the 2704's built-in amplifier you can have external op-amp.
Or look at the c-moy op-amp based designs.
None of these things qualify as audiophile. It is 192KHz 24 bit.
IMHO, these two requirements are mutually exclusive .
IMHO, these two requirements are mutually exclusive .You can get a motorized potentiometer, control the motor with the PIC.
If this is a 'project' for listening to vinyl then I'd build something with valves as a bit more of a challenge.
Where's the fun in using one of the hundreds of single-chip-solutions?
Where's the fun in using one of the hundreds of single-chip-solutions?See the links I placed in post #15...
