Author Topic: High Voltage Down Converter Circuit  (Read 2498 times)
Offline Pat PendingTopic starter
« on: September 12, 2012, 11:36:41 pm »
Does anyone know of a simple discrete DC/DC down converter from 75V to 12V@20mA?
Offline mariush
Re: High Voltage Down Converter Circuit
« Reply #1 on: September 13, 2012, 01:09:25 am »
That would be kind of hard to get one ready made, you have lots of options if you get that down to a maximum of 72v :
http://www.digikey.com/product-detail/en/VWRBS2-D48-S12-SIP/102-1519-ND/1558914
http://www.digikey.com/product-detail/en/VWRAS2-D48-D12-SIP/102-1535-ND/1558930
But you could build one yourself if you don't need it to be the isolated kind, look up the LM500x family of switching regulators. They take up to about 95v DC and regulate down to whatever you want, and they're about 2-3$ in 10-50 pcs quantity:
http://www.digikey.com/product-detail/en/LM5008AMM%2FNOPB/LM5008AMMCT-ND/2075647
http://www.digikey.com/product-detail/en/LM5009MM%2FNOPB/LM5009MMCT-ND/1001314
http://www.digikey.com/product-detail/en/LM5007MM%2FNOPB/LM5007MMCT-ND/599064
Add a couple of dollars in inductor, resistors and capacitors and you're done, cheaper than an isolated dc-dc converter.
Offline PSR B1257
« Reply #2 on: September 13, 2012, 06:29:52 am »
If you only need 20mA you might use a linear regulator - like the TL783 - instead.
As every other voltage regulator of that kind, it's programmable with just two resistors.
What kind of 12V/20mA load is this? If the 20mA are constant, you need just a single resistor.
In theory, there is no difference between theory and practice. But, in practice, there is.
« Reply #3 on: September 13, 2012, 07:30:17 pm »
Thanks Everyone
I'd been looking at the MAX5033, but then two issues arose, 1st it's expensive in small quantities and 2nd it's by Maxim
or rather no one carries a large stock whereas the LM500x is carried in the many thousands.
I was hoping for some sort of jelly bean buck converter if one still exists?
Offline PSR B1257
« Reply #4 on: September 13, 2012, 09:10:11 pm »
What about my questions... :o
To give you a propper suggestion, we need to know what you intend.
