Lets take the TL900x series:
https://www.ti.com/lit/ds/symlink/tlv9002.pdf"TLV900x Low-Power,
RRIO, 1-MHz Operational Amplifier for Cost-Sensitive Systems"
"The TLV900x family includes single (TLV9001), dual (TLV9002), and quad-channel (TLV9004) low-voltage (1.8 V to 5.5 V) operational amplifiers (op amps)
with rail-to-rail input and output swing capabilities."
7.10 Electrical Characteristics:
Output:
Vo - Voltage Output Swing from Supply Rails:
Vs = 5.5V, RL=10K --->
Typ 10mV, Max 20mV Vs = 5.5V, RL= 2K --->
Typ 35mV, Max 55mVSo this
Rail-to-Rail-Input-Output opamp can only actually get to best case output of 10mV of the rails, and worst case 55mv?
I understand this is significantly better than a nonRRIO part, but that could totally screw a design if those 10mV around zero were important.
Note: 10mV is good, but it's not "Rail-to-Rail".
Note2: I propose this:
For linear regulators we have "Low Drop Out". They don't call them "Zero drop out*" ....."*still need 0.4V".
How about "RRI-
LHO" = Rail-Rail-Input,
Low-Headroom-Output
