Author Topic: I need help creating a discrete DAC for an old project  (Read 3137 times)
Offline DaveHardyTopic starter
« on: May 27, 2023, 10:17:47 pm »
Hello, I'm trying to recreate a Burr Brown DAC 71 CSB I for a project I'm in the middle of.  The DAC itself is relatively easy and straight forward.  The problem is that this old DAC doesn't require a clock / latch instruction to output data, and I'm having trouble finding a primitive replacement or one that would allow me to tie the latch low for constant output.
Any suggestions or comments will be appreciated.
Online moffy
Re: I need help creating a discrete DAC for an old project
« Reply #1 on: May 27, 2023, 11:24:20 pm »
The DAC71 doesn't have a latch on its input, so whatever digital word is present on its input is converted to an analogue output. If you want a fixed value just provide a 16 bit latch or 2 eight bit latches. What logic are we talking here, 5V TTL/CMOS, 3.3VCMOS, FPGA etc.
Online Benta
« Reply #2 on: May 27, 2023, 11:44:10 pm »
Perhaps you should read the OP's question again...
Online moffy
« Reply #3 on: May 28, 2023, 12:15:07 am »
Perhaps you could help the OP since you understand the question better than I do. :)
Offline PCB.Wiz
« Reply #4 on: May 28, 2023, 01:32:21 am »
If that settles in 5us, can you not simply clock almost any suitable DAC at 200kHz or above, to emulate the same action ?
« Reply #5 on: May 28, 2023, 01:55:23 am »
Thanks for the comments everybody!  Regarding clock timing, I don't want to go that route unless I absolutely have to.  I found this IC.  It's V out instead of current out.  I think I can make it work in this circuit.  According to the datasheeet, holding everything low will create a pass through device.  I'll post the circuit next.
https://www.analog.com/media/en/technical-documentation/data-sheets/1657lfa.pdf
« Reply #6 on: May 28, 2023, 02:10:03 am »
Gain adjust is supposed to be calibrated for 5V + offset  from zero at pin 6 of U347.   I could install an op amp on a minature board with the DAC and a gain trimmer to get V out and omit U347.  Is this a good idea? What could go wrong?
« Reply #7 on: May 28, 2023, 02:25:43 am »
This might be an even better part!  This is a current DAC.
https://www.analog.com/media/en/technical-documentation/data-sheets/AD7538.pdf
Online moffy
« Reply #8 on: May 28, 2023, 02:30:15 am »
You have a latch signal that feeds into the 74174, if you wanted to you could forward that signal to the DAC and use anyone you liked.
« Reply #9 on: May 28, 2023, 02:37:26 am »
Those are separate latches for upper and lower byte.  If some parts in the program alternate high and low latches, I'm screwed.  I'd rather avoid all complications first.
Online moffy
« Reply #10 on: May 28, 2023, 02:45:43 am »
Nasty. There is the possibility to forward both latch signals and combine them into a single latch signal that updates on any change.
« Last Edit: May 28, 2023, 02:51:29 am by moffy »
Offline bobcherry
« Reply #11 on: January 02, 2025, 10:15:09 pm »
Hi Dave, Hope you don't mind me picking up on this post but did you have success with creating the DAC for the P5? I seem to be in a similar situation (P5 Rev3.0) :(
I'd appreciate any thoughts/advice. MTIA. Rob
