i have a oled panel with digitizer (KTH3915SUS chip-.) it is a dell xps 15 oled panel.
i have purchased a controller board
https://www.ebay.com/itm/165566515873 and connected to the panel. Have picture and everything seems ok.
want to use the digitizer to be able to have it like a touchscreen panel connected to a raspberry. On the controller board there is a touch port connector. Asked the seller about the pinout of the touch connector and if it will work. he said that i need to buy a new digitizer that fits to that controller board.
dont want to buy a new digitilizer with controllerchip when it is already on my panel.
The digitizer controllerboard is this one.
https://www.ebay.co.uk/itm/234694403755?hash=item36a4e066ab:g:XrkAAOSwmWRjIPQpPlan to connect this digitizer controllerboard directly to the raspberry. BUT...the interface FROM the digitizer board. is it USB? SPI? ic2?
Can i connect it directly to the rasberry in any way? and use it as a touchscreen for the raspberry os?
the connector from the digitizer controllerboard has 6 leads.... the pinout?
?? two negative...one +5V ?? positive and the rest?
Thanks
