Author Topic: Interface digitizer question  (Read 860 times)
Offline Tony.TTopic starter
  • I want to live in theory, everything works there!
« on: November 25, 2022, 02:45:00 pm »
i have a oled panel with digitizer  (KTH3915SUS chip-.) it is a dell xps 15 oled panel.
i have purchased a controller board https://www.ebay.com/itm/165566515873  and connected to the panel. Have picture and everything seems ok.
want to use the digitizer to be able to have it like a touchscreen panel connected to a raspberry.    On the controller board there is a touch port connector.  Asked the seller about the pinout of the touch connector and if it will work. he said that i need to buy a new digitizer that fits to that controller board.
dont want to buy a new digitilizer with controllerchip when it is already on my panel.
The digitizer controllerboard is this one.  https://www.ebay.co.uk/itm/234694403755?hash=item36a4e066ab:g:XrkAAOSwmWRjIPQp
Plan to connect this digitizer controllerboard directly to the raspberry. BUT...the interface FROM the digitizer board.  is it USB?  SPI? ic2?
Can i connect it directly to the rasberry in any way?  and use it as a touchscreen for the raspberry os?
the connector from the digitizer controllerboard has 6 leads....  the pinout??????  two negative...one +5V ?? positive  and the rest?
Thanks
« Last Edit: November 25, 2022, 02:53:20 pm by Tony.T »
