Author Topic: Jellybean N Channel FET for 3V logic  (Read 11258 times)
Offline forrestcTopic starter
« on: July 25, 2016, 09:02:23 am »
Quite a while back I used to use the 2n7000 and 2n7002 fets in everything.   When I switched to 3.3V logic for my designs, the 2n7000 didn't really have a low enough Vgs(th)to make me happy, and the Ron at 3V wasn't very good either.   I spent some time looking for a FET alternative, and didn't really find any which met my needs (which included high Vds).  At some point someone asked the pointed question as to why I wasn't just using a jellybean NPN transistor instead, and after about 5 seconds of  :-//, I switched to a MMBTA06 in everything.
Now I have an application where I need a FET - I.E. need to do basic slew rate control and need to go all the way to the negative rail.  So I'm back to looking for a good jellybean part (cheap, widely available).  Or at least something somewhat jellybean.  I'm finding quite a few parts, including the FDV303N, which seems like a good part which is well-stocked.   Does anyone else have a favorite N Channel FET driveable directly from 3.3V logic?
Offline Milentije
Re: Jellybean N Channel FET for 3V logic
« Reply #1 on: July 25, 2016, 09:11:25 am »
BSS138, but be careful, check RDSon.
« Last Edit: July 25, 2016, 09:13:46 am by Milentije »
The following users thanked this post: forrestc
Offline kony
  • Country: cz
« Reply #2 on: July 25, 2016, 09:14:57 am »
BSS138.
Using bipolars is totally fine, if you don't mind the need for additional resistors, Vce voltage drop, and increased static power consumption.
Offline Marco
« Reply #3 on: July 25, 2016, 09:21:40 am »
It's nice that all those ancient MOSFETs like 2n700x and BSS138 are still around for when you want sub pA gate leakage, but if you don't it's a bit silly to use them.
Offline DutchGert
« Reply #4 on: July 25, 2016, 09:44:19 am »
Then what would you suggest? BSS138 has been my jellybean logic level FET for ages. It's 50V, available in automotive specs and is dirt cheap.
Offline Chalcogenide
« Reply #5 on: July 25, 2016, 10:06:46 am »
The AO3400 is fairly cheap and has an RDSon of 52mOhm with 2.5V Vgs; 30V Vds max. It's quite a power-oriented MOSFET however, with 630pF of input capacitance.
Offline Fungus
« Reply #6 on: July 25, 2016, 10:12:19 am »
Use a BJT to drive your 2n7000.  :popcorn:
« Last Edit: July 25, 2016, 10:21:42 am by Fungus »
Offline Marco
« Reply #7 on: July 25, 2016, 10:20:16 am »
DutchGert : Not an endorsement, but searching for AEC-Q101 rated small signal MOSFETs in that range with gate protection ... DMN53D0xx? Or NVJD5121N, but that's a dual.
Not having to worry about blown gates is worth a few cents IMO.
« Last Edit: July 25, 2016, 10:27:32 am by Marco »
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #8 on: July 26, 2016, 02:24:35 am »
2N7002 (for when you don't need much load current, or operation at low temperatures)
BSS138
FDV301N
AO7400
Seven Transistor Labs, LLC
Offline Jay_Diddy_B
« Reply #9 on: July 26, 2016, 03:33:04 am »
I just happen to have the transfer characteristics of a randomly selected 2N7002 (Diodes Inc.) measured with my HP4155B Semiconductor Parameter Analyzer.
The 4155B is a collection of four Source Measurement Units (SMUs) that can be programmed to step and measure semiconductor parameters. Think of it as an accurate, programmable curve tracer.
Notes:
The horizontal axis is linear, the gate source voltage, Vgs, from 0 to 2V
The yellow trace is logarithmic that extends from 1 femto Amp (1E-15) to 100 milli Amp (1E-1) an astonishing 14 decades.
The blue trace is transconductance, 0 in the middle of the screen and 10 milliamps / volt at the top.
This is a single sample at room temperature.
With Vgs =0V, the drain current is 1pA
with Vgs = 1.6V the drain current is 1mA
The speed will be determined by the gate drive and the capacitances.
Regards,
Jay_Diddy_B
Offline grouchobyte
  • Country: cn
« Reply #10 on: July 26, 2016, 03:38:01 am »
BSS138
FDV301N
AO7400
Tim's recommendations are on my "goto to" list too :-+ :- :-+
Offline SteveyG
  • Soldering Equipment Guru
« Reply #11 on: July 26, 2016, 07:45:30 am »
FDV303N is my usual.
YouTube Channel: https://www.youtube.com/user/sdgelectronics/
Use code: “SDG5” to get 5% off JBC Equipment at Kaisertech
Offline DutchGert
« Reply #12 on: July 26, 2016, 08:42:20 am »
FDV301N is a nice one indeed, Diodes even has a Automotive Qualified one: DMG301N (http://www.diodes.com/catalog/N_Channel_8V_to_29V_106/DMG301NU_10655)
« Last Edit: July 26, 2016, 08:45:10 am by DutchGert »
Offline Marco
« Reply #13 on: July 26, 2016, 11:11:05 am »
To make a device able to control leakage to that extent unprotected gate MOSFETs are nice, for everything else pick something with gate protection :)
Offline T3sl4co1l
« Reply #14 on: July 26, 2016, 10:57:55 pm »
Also, 3LN01M-TL-H
« Reply #15 on: July 27, 2016, 02:21:43 am »
It's a bit silly to add cost to every FET when you're driving them from a microcontroller, especially since the microcontroller would be good and fried well before exceeding the Vgs rating of the FET's...
(Talking from the standpoint of volume production here).
Although I will say I didn't even realize there were FET's with gate protection... so I do have some interesting ideas about using them for input protection (something I had never considered).
Offline T3sl4co1l
« Reply #16 on: July 27, 2016, 03:05:32 am »
I don't think I've seen MOSFETs rated for more than 2kV HBM.  Input protection, uhhh...
Offline Marco
« Reply #17 on: July 27, 2016, 03:31:50 am »
Often it's going to be the only component on a PCB with a HBM rating of 100V, with everything else being multiple kV. That represents an opportunity cost, change the 2n700x and suddenly the handling requirements for assembly are much looser.
« Last Edit: July 27, 2016, 03:38:35 am by Marco »
Offline daveatol
« Reply #18 on: July 27, 2016, 04:24:03 am »
The cheapies I saw on ebay are: SI2302, Irlml0030 and BSS138
Offline Siwastaja
« Reply #19 on: July 27, 2016, 07:21:44 am »
You never buy discrete semiconductors on Ebay because they are over 90% inoperational fakes, and typically more expensive than the good parts.
Online nctnico
« Reply #20 on: July 27, 2016, 10:58:13 am »
I like to use the SI2302 as well (bought from a credible source ofcourse).
Offline baoshi
  • Country: sg
    • Digital Me
« Reply #21 on: July 27, 2016, 11:07:20 am »
2N7002 is pretty easily damaged by ESD compared to BSS138.
Offline David Hess
  • DavidH
« Reply #24 on: July 27, 2016, 01:34:46 pm »
If low Vebo and low current gain are acceptable, then you can use a bipolar transistor with the emitter and collector reversed to provide a much lower saturation voltage.  They used to make special bipolar transistors for this application but no more.
