Author Topic: KiCad one schema, multiple layouts? [SOLVED]  (Read 4958 times)
Offline onesixrightTopic starter
« on: June 13, 2016, 09:15:48 am »
For the life of me, i can't figure out how to create two PCB's (or more) layouts based on one Schema.
Running KiCad 4.x
Anyone has a clue?
Much obliged!
« Last Edit: June 13, 2016, 10:34:17 am by onesixright »
Offline madires
  • A qualified hobbyist ;)
Re: KiCad one schema, multiple layouts?
« Reply #1 on: June 13, 2016, 09:30:07 am »
Copy the project and create a PCB for each project?
« Reply #2 on: June 13, 2016, 09:36:28 am »
Yeah that came to mind, but if you change the schema. You need to do it twice.
Im designing a circuit for a THT and SMD layout. So one schema, 2 layouts  :-//
Offline Wilksey
« Reply #3 on: June 13, 2016, 09:53:41 am »
I haven't tried it, but you could try creating the default (say THT) PCB within the project, open PCBNEW.exe (from the KiCAD install), create a new PCB based on the netlist from the project, save the (presume SMT) PCB into the project folder, then you should, in theory, have both PCB's within the project.
I don't think KiCAD has back / forward annotation so I don't think you will sever any links between them, it all used to be done by manually importing the netlist.
Try it!
Re: KiCad one schema, multiple layouts? [SOLVED]
« Reply #4 on: June 13, 2016, 10:14:46 am »
Well, found it. Not sure if its logical, but you basically open the layout, then then goto File -> Save As.
That essentially makes a copy (.kicad_pcb).
Thanks for the help!
Offline Thor-Arne
  • Country: no
  • tinker - tinker, little noob.....
« Reply #5 on: June 13, 2016, 01:25:44 pm »
I'm not sure this will work as KiCad stores the footprints in the schematic file (F2 field) in addition to in the netlist file.
$Comp
L CP C1
U 1 1 555F3EC3
P 2600 5650
F 0 "C1" V 2650 5750 40  0000 L CNN
F 1 "22uF Tan" V 2550 5350 40  0000 L CNN
F 2 "Caps_SMD:cap_smd_tant_C" H 2600 5650 60  0001 C CNN
F 3 "" H 2600 5650 60  0000 C CNN
1    2600 5650
1    0    0    -1
$EndComp
In addition there is a major refactoring is going on with the eeschema code, so these kind of workarounds might not work in the future.
Also, this post should be in General PCB/EDA/CAD Discussions » KiCad.
« Reply #6 on: June 13, 2016, 01:28:23 pm »
@Thor-Arne
I got it (see message).
Any moderator that can move this to the correct folder (sorry didn't realise that)?  :palm:
