Author Topic: Lambda diode  (Read 3069 times)
Offline temperanceTopic starter
Lambda diode
« on: June 06, 2025, 12:00:08 am »
I just came across something called a lambda diode. This is a circuit made with 2 JFET's connected together which show a resistance graph similar to that of a tunnel diode.
https://en.wikipedia.org/wiki/Lambda_diode
Some practical circuits with lambda diodes:
https://www.cxi1.co.uk/Theory/neg_resistance/negres.htm
I don't need this but I find it interesting.
The following users thanked this post: TimFox, RoGeorge, D Straney, SteveThackery
Offline RoGeorge
Re: Lambda diode
« Reply #1 on: June 06, 2025, 07:45:08 am »
Nice!  :-+
A reversed BJT (with C and E swapped) also shows negative resistance.  Certainly can make an oscillator, not sure if anybody tried a regenerative receiver with reversed BJT.  :)
https://www.eevblog.com/forum/beginners/why-when-this-transistor-appears-to-be-reversed-does-this-circuit-work/msg5923648/#msg5923648
https://www.eevblog.com/forum/testgear/fooln-around-with-dso-awg/msg4422982/#msg4422982
The following users thanked this post: pardo-bsso
Re: Lambda diode
« Reply #2 on: June 06, 2025, 09:41:23 am »
Thanks RoGeorge for the interesting links.
Offline LaserSteve
Re: Lambda diode
« Reply #3 on: June 06, 2025, 03:26:21 pm »
Please enjoy the link and attachment. This is one component that I wish was back in serial production. You can do this with paired discrete parts. There are a ton of bipolar and fet variations.  Using these parts as oscillators can reach well into VHF if done properly.
https://www.qsl.net/vk5br/NegativeResistance/NegResDipMeter.htm
Recently this combination has been rediscovered for memory elements and low battery indicators.
Steve
« Last Edit: June 06, 2025, 03:39:31 pm by LaserSteve »
"I calculated the stored energy, and it is enough to play the Dance / DJ Extended edition of "Baby Shark" in all 100 headsets for the production floor team simultaneously over 100,000 Times."
Well, I had to explain it to my boss, somehow.  He's an Accountant,  not a PHB.
Online Alex Nikitin
  • Femtoampnut and Tapehead.
    • A.N.T. Audio
Re: Lambda diode
« Reply #4 on: June 06, 2025, 03:43:07 pm »
That brings back some old memories. I've used this configuration (made from two discrete JFETs, obviously) in the RF oscillator circuit of the super heterodyne SW radio receiver I've built around 1978 (I think  ::) ).
Cheers
Alex
Offline Grandchuck
Re: Lambda diode
« Reply #5 on: June 06, 2025, 05:12:58 pm »
Offline TimFox
Re: Lambda diode
« Reply #6 on: June 06, 2025, 05:40:35 pm »
I've fooled around with an interesting vacuum-tube circuit, the "transitron", to build voltage-tunable HF oscillators.
The first 6AS6 dual-control pentode (basically a 6AK5 with the suppressor grid modified to function as a second control grid) is the oscillator:  the transitron circuit generates a negative conductance that is connected in parallel with the LC tuned circuit.
A second 6AS6 connected as a "reactance modulator" to the same tuned circuit makes voltage-controlled capacitance (or inductance) in parallel with the LC circuit to change its frequency;  the control voltage goes to the suppressor grid to change the transconductance of the pentode.
Transitron: https://books.google.com/books?id=e_oZ69GAuxAC&pg=PA79&lpg=PA79&dq=transitron+oscillator&source=bl&ots=v-nK1uhV3n&sig=ACfU3U0HN6HCz8jiyvgkR2MbEeWDbD7lig&hl=en&sa=X&ved=2ahUKEwioksu7yZr7AhUBpokEHfQlBvQ4ChDoAXoECBAQAw#v=onepage&q=transitron%20oscillator&f=false
Reactance modulator:  https://www.one-electron.com/Archives/Radio/RadioFM_Tech/Hund%201942%20Reactance%20Tubes%20in%20FM%20Applications.pdf
The transitron tube circuit replaced the earlier "dynatron" circuit that exploited the secondary emission problem with a tetrode, when the plate voltage was lower than the screen-grid voltage.
However, the dynatron was sensitive to the condition of the plate itself, which changed its secondary emission charactistics.
The transitron uses a pentode, which suppresses the secondary electron emission, and depends on well-controlled control characteristics of the suppressor and screen grids.
Re: Lambda diode
« Reply #7 on: June 06, 2025, 06:25:21 pm »
Now I must order some JFET's...
Offline coppercone2
  • √Y√... 📎
Re: Lambda diode
« Reply #8 on: June 06, 2025, 08:49:15 pm »
an answer to peak tunnel diode? but the voltage is too high. 6V  :'(
Offline TimFox
Re: Lambda diode
« Reply #9 on: June 06, 2025, 09:05:56 pm »
Looking at the various discrete-circuit examples quoted above, the peak voltage varies considerably from design to design.
Offline coppercone2
  • √Y√... 📎
Re: Lambda diode
« Reply #10 on: June 06, 2025, 09:18:20 pm »
the tunnel diode is 60mV
I am almost amazed with how 'hot' quantum is, there is no tunnel diodes anymore (quantum device)
I guess it needs to be shiny to be popular (laser)
Re: Lambda diode
« Reply #11 on: June 06, 2025, 09:31:11 pm »
No, and that wasn't the point.
Offline MariuszD
Re: Lambda diode
« Reply #12 on: June 07, 2025, 10:11:06 am »
This circuit with bipolar transistors also exhibits negative resistance.
https://www.edn.com/simple-5-component-oscillator-works-below-0-8v/
The following users thanked this post: temperance
Offline tggzzz
Re: Lambda diode
« Reply #13 on: June 07, 2025, 10:42:26 am »
And the author is on this forum, currently with 4447 posts :)
