Author Topic: laser diode  (Read 1392 times)
Offline decoevvblogTopic starter
laser diode
« on: February 20, 2023, 02:49:59 pm »
I wanted some help kindly
can i use the same digital potentiometer for 9 laser diode?
obviously I will have a single setting for all 9...
1721342-0
Online moffy
Re: laser diode
« Reply #1 on: February 20, 2023, 09:33:19 pm »
The connection of LD1 is curious, especially what I assume is the photodetector connection to ground? Yes you can use the same output from the digital potentiometer to drive other laser diodes via the LM324, as the +ve input is relatively high impedance, the most you would need to worry about is input bias currents into the LM324s creating an offset in the digital pot.
Offline NiHaoMike
    • Facebook Page
Re: laser diode
« Reply #2 on: February 21, 2023, 01:50:01 am »
Put a 100k or so pulldown on the noninverting input of the opamp to ground, so that a bad connection won't cause it to go to max current from bias current.
BTC: 18813fu8LQEdDwH9YLM1ABed3XwCfeSeFi
The following users thanked this post: MegaVolt
