Author Topic: load circuit  (Read 2690 times)
Offline Alex QWTopic starter
load circuit
« on: March 14, 2023, 05:57:55 am »
Hi all,
May I know how this TTL load circuit work as shown in the below diagram?
Note that: 1)the red arrow means the microcontroller control signal (1,2)
                2) Is the TTL output pin (3,4)
The circuit is in this link: https://forum.allaboutcircuits.com/threads/ttl-load-circuit.192516/
Thank you.
Best Regards
Alex.
Offline Terry Bites
Re: load circuit
« Reply #1 on: March 14, 2023, 09:50:31 pm »
Erm. I'm not registering with your website.
You didn't give out any information on your circuit there either!
A TTL load is an equivalent circuit of a TTL gate input.
Have a look at the TTL wiki page.
see www.interfacebus.com/Glossary-of-Terms-TTL-Load-Circuits.html
Re: load circuit
« Reply #2 on: March 15, 2023, 01:23:01 am »
May I know why they use a lot of diodes in the circuit?
Offline Kim Christensen
Re: load circuit
« Reply #3 on: March 15, 2023, 04:30:48 am »
Attach the picture of your circuit here. Most people can't see it on allaboutcircuits.com since we don't have an account.
The following users thanked this post: Alex QW
Re: load circuit
« Reply #4 on: March 15, 2023, 06:09:37 am »
This is the circuit diagram
Sorry for any inconvenience as I just joint this forum not so familiar with this feature
Offline Terry Bites
Re: load circuit
« Reply #5 on: March 15, 2023, 11:41:10 am »
The bias resistors set up a current (1.2mA) in the diodes going to ground- this sets VIL for the equivalent gate input plus a diode drop. You then subtract a diode drop ((D604)  from this voltage.
This sets the lower threshold to a bit over VIL.
Re: load circuit
« Reply #6 on: March 23, 2023, 01:14:19 am »
how to know that the bias resistors set up a current (1.2mA)?
