Author Topic: Making a PWM based voltage standard.  (Read 36243 times)
Offline Doctorandus_PTopic starter
« on: September 02, 2021, 10:05:58 pm »
Some time ago I got a bit interested in generating variable reference voltages. I first had a bit of thought about Kelvin-Varley, but it seems a bit obsolete, bulky & expensive.
So I did a bit more research and everybody seems to use PWM these day's.
PWM is inherently linear, and does not need precision parts (or just a few of them).
So I did a few simple calculations, based on the attached schematic.
If you take a 16-bit PWM output of a 100MHz microcontroller, then you've got a PWM frequency of around 1.5kHz.
A 3rd order low-pass filter of around 15Hz or  = 94 rad/s seems appropriate. With a 6 time constants settling time it's stable after around 63ms which is good enough to 10+ measurements per second in some automated setup.
A single filter stage does 20dB /decade, so 2 decades * 3 orders * 20dB = 120dB dampening of the PWM ripple. (Back of envelope calculations, but accurate enough).
Maybe throw in some resistor sized inductors to get a passive 6-stage filter. The beauty here is that the whole filter is non-critical No precision parts needed. The only critical parts of the filter are probably the leakage through the PCB and the capacitors, and the buffer opamp bias current. so good quality capacitors are needed, but only a few of them.
But a 16 bit PWM is not very impressive. It will have very noticeable steps in it's output voltage. So then you add another identical stage, and connect them with a high ohmic resistor (Oops I goofed up: 1uF * 100M Ohm = 100s time constant). But the overall Idea is clear. The second stage adds a bunch of small steps in between the main PWM generator, and exactly how many of those steps and their size is a software calibration.
For the switches I think that a simple 74HCT541 is a reasonable choice. By using all 8 outputs parallel the differences between the N- and P- channel mosfets become less important. The 74HCT541 itself is powered from the (constant) voltage reference. Asymmetry between rise and fall times is probably fairly easy to calibrate out. It's got a 100MHz or so microcontroller on board (I'm thinking of 168MHz STM32F411 from the WeAct Black Pill)
I think this is a recipe for a quite good but still low cost variable voltage generator. Most of the parts are cheap and easily available. I have not thought much about what voltage reference and opamp to use. (Opamp has to be a precision type with FET inputs and low bias current).
Overall this may be a better option compared to the Kelvin-Varley variant with steppermotors I also posted here:
https://www.eevblog.com/forum/projects/making-switch-contacts-for-kelvin-varley-project/
1. Did I make some gross errors here, or does the idea look quite sound?
2. How good could such a thing be? Would a very good voltage reference be a waste for this application?
3. Alternatives for the PWM buffer? Maybe a MOSFET gate driver or analog switch (but these get more expensive quickly, and are more difficult to obtain)
« Last Edit: September 02, 2021, 10:08:48 pm by Doctorandus_P »
Online moffy
Re: Making a PWM based voltage standard.
« Reply #1 on: September 03, 2021, 01:21:37 am »
PWM is not perfectly linear because leading and falling edges have finite times. Clocks also have jitter etc., plus PWM is inherently noisy. You would get better performance using an FPGA than a micro, faster I/O. But along with precision of voltage, a voltage reference needs to be low noise, PWM just isn't going to compete with inherently linear voltage sources. Also for PWM based Vref the supply to the logic needs to be a Vref, which needs to supply the load current for the logic including the switching glitches, not a good formula.
« Last Edit: September 03, 2021, 01:58:40 am by moffy »
Offline Nominal Animal
« Reply #2 on: September 03, 2021, 12:46:36 pm »
Do consider pulse density modulation instead.  (Say, an N-bit counter incremented by the duty at each cycle, with the most significant bit determining the output signal state.)
Except for duty very close to 0% or 100%, the resulting spectrum is much easier to filter out.
If you limit the duty range to say 6.25% to 93.75% (1/16 to 15/16), the maximum interval between transitions is 16 cycles.  Most of the noise to be filtered out in PDM is therefore very high frequency (compared to PWM), and easier to filter out.  (In general, restricting the duty range to 1/N to (N-1)/N, inclusive, ensures the maximum interval between transitions is N cycles.)
There are obvious downsides, of course.  One is the much greater number of transitions (and therefore the switching transistors are in their linear region a larger fraction of time, yielding a higher power consumption; and possibly nonlinearity etc. due to asymmetric rising/falling transition rates).
Offline Kleinstein
« Reply #3 on: September 03, 2021, 02:11:09 pm »
The filtering is not working that well with 3 stages just passively connected. It is a lreatively low load to the switches (P to N symmetery gets important) and the output is still quite high in impedance. The roll of is still relatively soft. There are better suited filters, that also avoid  an extra OP in the signal path.
The Logic chip for switching is kind of OK, though not ideal. The voltage is relatively low and thus errors at the output buffer get relatively important.
CMOS switches look like a reasonable compromise. something like DG419L, maybe DG403 could be a possible alternative. They have the advantage that the gate drivers use a separate supply and thus less spike to the reference.
I would not go all the way to pulse density modulation, as this would give a variable switch frequency. More like a littel modulation on top of a PWM for the last 1-3 bits.
I know that some classic solutions use 2 x similar PWM, but I would avoid it. For the lower bits I would just use an of the shelf DAC. At some 8-12 bit this is not a big deal and avoids possible interaction between the 2 channels when the transistions happen at the same time.
The simple solution as shown may not be very linear due to the switch resistance. For the residual ripple it depends a lot on the layout and how sensitive the reference is to pulsed load. Some refrence chips have quite a good output driver, some would need an extra buffer.  A µC inernal PLL to generatore the higher clock speed can have quite some jitter - it depends on the details. Especially non integer PLL ratios can be bad.
Online moffy
« Reply #4 on: September 03, 2021, 03:22:43 pm »
Sigma-Delta DACs do use switched pulses fed into an analogue filter, simplest is just an integrator, but they involve a lot of design. I have previously built  a Sigma-Delta ADC on a breadboard but the best I got was about 14 bits with some drift. It gets a lot harder to get better results.
Offline Kleinstein
« Reply #5 on: September 03, 2021, 04:55:50 pm »
The simple sigma delta ADC/DAC don't get a constant numbers of switchings and this is a big problem for linearity. A simple PWM or slightly modulated PWM is better for linearity. For the start, just simple 16 bit PWM is OK. A little slower and as compensation a better (less rounded transition) is probably easier, as the switching adds to the errors.
Different rates for falling an rising are not such a problem. The probelm there is more if the rates drift. Chances are one would need to trim / measure the zero anyway because of different delays and even AZ OPs still having some offset. Nonlinearity comes in when the reference buffer is not yet settled before the switch is operated again. More switching also sums upt the error from more such events.
Offline iMo
  • Country: li
« Reply #6 on: September 03, 2021, 07:05:04 pm »
In Metrology section - thread "LM399 based 10 V reference" there is a long series of posts related to making a pwm based voltage standard, aprox from replay 850 to 950 (+/-50)..
« Last Edit: September 03, 2021, 07:07:52 pm by imo »
Online macaba
« Reply #7 on: September 03, 2021, 09:05:54 pm »
I've built a precision PWM DAC so the following is based on that experience:
- There will be a non-linearity, the midpoint will be the worse error, additional circuitry is normally needed to reduce the current going though the main switch.
- There will be a long settling time for the filter due to dielectric absorption. As a rough rule-of-thumb, I discovered WIMA polypropylene 2.2uF takes around 60-90 seconds to settle to <0.1PPM. That's a very good capacitor.
Offline Badwolf
« Reply #8 on: September 04, 2021, 10:06:28 pm »
The PWM reference is used in many calibrators considered to be rather efficient, e.g.: Adret 103 and 104, Valhalla 2701C. The latter is quite interesting and simple to study if one makes abastraction of the FET cascade for the generation of the 1000v.
For the filter, I recommend the one used especially in the 2701C which is of the type zero-offset active lowpass (a description is available on EDN https://www.edn.com/zero-offset-active-lowpass-filter-part-1). It makes it possible to have good filtering without the usual inconvenience of conventional active filters (offset drift, ...)
The simplest explanation is almost always somebody screwed up (Dr. House)
The following users thanked this post: iMo
Offline iMo
  • Country: li
« Reply #9 on: September 05, 2021, 10:54:45 am »
Some sims with above zero offset low pass
« Last Edit: September 05, 2021, 11:20:43 am by imo »
« Reply #10 on: September 09, 2021, 12:06:22 pm »
It's been a week now since my first post.
It took me some time to digest it all. especially the LM399-10V-standard thread.
It's become abundantly clear that when you go over 3 digits or so of precision / accuracy / repeatability / etc, then all sorts of small details become important.
My main goal is not to build a perfect voltage standard, but to design and build some measurement equipment for a low budget, but still very usable and affordable. Similar to the Scullcom series, which I quite like.
I think I first start with some simple power supplies. Maybe just a symmetrical power supply from 2x 18650 with built in protection circuits. Then expand with some ADS1118 ADC on a uC for logging data for a few days. For example, build two uC's with PWM based Reference voltage generators, set them to the same voltage output, and then log drift between them. I also still have to do linearity, noise and drift characterization of the HX711 I've got lying around.
I do have the reference manual with full schematic of an old Kelvin-Varley Fluke reference thingie with oil baths, but I do not have a full schematic of any of the more modern PWM based equipment. some block schematics, those do not have enough details for filtering and such. Can't find a (free) schematic of the Valhalla 2701C. Adret 103 was mostly French (Yuck) only block schematic and no full schematic.
The EDN article for zero-offset active lowpass filtering is also interesting, but putting 200k in series is not good for wanting to measure 5+ digits accurate DC. At the moment I'm leaning much more towards a passive (dampened) LC filter approach. Low DC resistance, High dampening for higher frequencies, and maybe add a double pi for sucking out the PWM base frequency. Passive filter is relatively easy to design, because I do not need a sharp corner frequency nor a very linear response just below the corner. I just want high suppression for frequencies of two orders of magnitude above DC  ;D
There is lots of room for experimentation. I've got an old Rigol DS1052E but such scopes (and scopes in general) lack accuracy. The old trick for using an audio card for measuring audio-frequency stuff may still be the best option for a low-budget approach.
I also value the remarks of the 74HCT versus analog switches and the DC reference loading. AD411 are above my budget for a thing like this though. but the remark is important enough to also build some 4053 based variant, put some of the switches parallel and compare differences in DC, charge injection, leakage, asymmetric switching and other things that can introduce non-lineairity. One of the experiments is probably to build both 74HCT and 4053 variants, and compare linearity.
I've thought about pulse density modulation.
It's probably not a good idea for this. DC voltage can be extracted sufficiently with a better passive filter (8 stage LC?) while more flanks introduce more non-linearity.
Static 5V voltage standard IC's are another issue. These things become expensive quickly when you want more stability. My goal would be to have around 10ppm resolution / accuracy and drift per year for an EUR10 total BOM cost (exclusive power supply, PCB), and preferably also with readily available (no vintage) parts.
« Last Edit: September 09, 2021, 12:15:59 pm by Doctorandus_P »
Offline mawyatt
« Reply #11 on: September 09, 2021, 01:35:06 pm »
A technique we utilized decades ago in our precision FOG work was to employ an Elliptic (Cauer) or Inverse Chebyshev low pass filter for analog waveform smoothing. The filter transmission zeros were located to suppress the fixed frequency components in the input, this is similar to what DMMs do digitally for AC mains line frequency suppression. You can also utilize a twin "T" notch filter at the interfering frequency along with a regular Low Pass for smoothing.
Best,
« Last Edit: September 09, 2021, 01:52:50 pm by mawyatt »
~Wyatt Labs by Mike~
Offline Badwolf
« Reply #12 on: September 13, 2021, 07:06:16 pm »
In case you want some info on the Adret and the Valhalla. Here are the documents of these 2 devices.
The Valhalla diagram is slightly easier to understand.
Offline Echo88
« Reply #13 on: September 13, 2021, 07:59:11 pm »
Throwing in the Fluke 5700A PWM DAC:
https://xdevs.com/doc/Fluke/5700a/Fluke_5700A_5720A_Multi-Function_Calibrator_Service_Manual.June_1996.pdf Page 514
With a good explanation of the DAC on page 123.
Offline MIS42N
« Reply #14 on: September 14, 2021, 05:36:44 am »
Although it isn't a voltage reference, I am using a PWM to source the control voltage for an OCXO. It is a 10 bit PWM driven at 40kHz from a PIC16F1455. In software, the width of every pulse is varied (if necessary) to generate voltages between what would be obtained using fixed pulse width. The base number used is 24-bit and the voltage is from 0 to 5V resulting in steps less than a microvolt. At 40kHz the bit stream repeats more than twice a second, and the application only needs to change the voltage once a minute or more. The filtering I use is adequate for the application. The output probably has all the non linear behaviour others have pointed out, but this could be compensated in software by comparing a few points against a better reference.
Just throwing the idea into the mix. No messy combining two sources into one.
Offline Kleinstein
« Reply #15 on: September 14, 2021, 08:18:42 am »
Combining 2 parts is not that complicated. The main difficulty is getting the scale factor right for the small part. So it needs a way for the adjustment. However in many versions one would need a way to check / set the zero point anyway and using this also for the fine scale is not that much extra effort (mainly software).
For the fine part I would prefere a ready made DAC - some 8-10 bit accuracy could be sufficient with enough resolution from the main PWM.
The Fluke5700 circuit is quite a bit confusing. The 57LFC has a  somewhat simpler version, using CMOS DG411 switches instead of discrete fets. The linearity compensation is also easier to understand in that form.
Using HC4053 type switches would limit to reference level to some 7 V (e.g. as +-3.5 V). Lower voltage makes amplifier offsets more important. At the very low cost end a 5 V ref. may still be OK, but it limits the performance a little.
Offline iMo
  • Country: li
« Reply #16 on: September 14, 2021, 08:48:09 am »
.. In software, the width of every pulse is varied (if necessary) to generate voltages between what would be obtained using fixed pulse width. The base number used is 24-bit and the voltage is from 0 to 5V resulting in steps less than a microvolt. ..
How do you do that in sw?
Offline MIS42N
« Reply #17 on: September 14, 2021, 09:39:49 am »
Timer 2 is the counter for driving the PWM, and for other reasons it is set to loop at 250 (25ms). On the timer interrupt, enter the interrupt routine:
; Timer 2 determines the length of each PWM output. The duty cycle of
; each pulse is dithered each interrupt. In software, the PWM value is
; held as 24 bits. The most significant 10 bits are loaded into the PWM
; duty cycle register. The least significant 14 bits of the 3 byte PWM
; value are repeatedly added to the value Dithr. If Dithr overflows to
; the 15th bit then the duty cycle is increased by 1 bit for the next
; PWM pulse.
BANKSEL PWM
MOVF    PWM,W   ; Add the least significant
ADDWF   Dithr,F   ; 14 bits of PWM to Dithr
MOVF    PWM+1,W
ANDLW   0x3F ; truncate to top 6 of 14 bits
BTFSC   STATUS,C
ADDLW   0x01 ; add in carry
ADDWF   Dithr+1,W ; add to the current Dithr
BTFSC   WREG,6 ; was there 14 bit overflow
BSF STATUS,C
MOVWF Dithr+1
MOVF    PWM+1,W ; now work out the top 10 bits
ANDLW   0xC0 ; get least significant two bits of 10
BTFSC   STATUS,C
ADDLW   0x40 ; yes, increase duty cycle 1 bit
MOVWF   PWM2DCL ; save 2 bits for inserting in CCP1CON
MOVF    PWM+2,W ; top 8 bits of duty cycle
BTFSC   STATUS,C
INCF    PWM+2,W ; add 1 if there was a carry from bottom 2 bits
MOVWF   PWM2DCH ; and store it as top 8 bits of next pulse width
Although it is called 40,000 times a second it only takes about 15% of the available cycles with a 10MHz instruction rate. The PIC PWM is double buffered so there's no problem writing the next value asynchronously. Hope it makes sense. If all the PIC was required to do is generate the bit stream the Timer could be set to 64, so only 8 bits are loaded into the PWM (effectively an 8 bit PWM) which would make the bit fiddling much easier. The output pulse rate would be 4 times higher making filtering easier.
Offline Kleinstein
« Reply #18 on: September 14, 2021, 09:52:56 am »
For the modulation of the PWM ratio there is a rather simple way like 1st order sigma delta. The set values is with a higher resolution and the difference between the set value and the values actually send out as PWM is summed up. The summed up part from the past is included in calculating the next pwm setting. With this simple method the PWM setting switches between 2 adjacent values. The natural implementation has the adjustment in the PWM timer ISR to calculate the next setting. Often the timer HW support suitable buffering / shadow registers.
There are also ways to do higher order SD modulation, e.g. like the MASH converters used for audio. It is a little more math, but still not that much. The PWM setting may change even by 2. I would still not go so high in the PWM frequency, as the switching part adds errors. Somthing like 1 kHz should be enough to get easy filtering and reasonable fast settling on a step. The modulated part has lower frequencies, but these are with a significant lower amplitude. So the normall fitler would still be good for the much smaller residual part at 500 Hz to 100 Hz. The subharmonics start out much lower (e.g. 1/10000).
Ideally the digital moulation should be of a similar order as the analog filter.
Offline MIS42N
« Reply #19 on: September 14, 2021, 12:26:20 pm »
Exactly what the bit of code I posted does (but not particularly elegantly). The set value is named PWM (3 bytes), the summed up part is Dithr (2 bytes, 14 bits used). And yes, the PWM hardware does the buffering. I noticed after posting that the code was cut and paste from a PIC16F628A to a PIC16F1455. The latter has an expanded instruction set and some of the cumbersome carry code could be cut out by using ADDWFC (add with carry) which wasn't in the original instruction set. But if it ain't broke ....
Offline iMo
  • Country: li
« Reply #20 on: September 14, 2021, 05:13:58 pm »
While g..ling on the dithering I found this pdf doc (ST) on PWM dithering (for stm32 mcus).
They use a table in sram with dithering patterns which create the lowest ripple, reading them via the dma into the pwm registers.
« Last Edit: September 14, 2021, 05:38:53 pm by imo »
Offline Kleinstein
« Reply #21 on: September 14, 2021, 05:48:22 pm »
The table and DMA solution is convenient if only a slightly higher resolution is aimed for and the hardware provides this feature. Not all µCs offer this option.
Some of the STM32 µCs (and also some other comparable µCs) provide very high resolution PWM with added interpolatoin for the timing. So they get PWM resolution as if the base clock would be in the GHz range. So they may provide 20 or even 24 bit PWM resolution at a reasonable frequency without a fine part.
edit: However there may be a timing problem: delivery in may 2022 with some luck.
Offline iMo
  • Country: li
« Reply #22 on: September 14, 2021, 05:52:17 pm »
Here is the source https://www.st.com/en/embedded-software/x-cube-pwm-dithr.html
And yes - the stm32f334 - has a 217ps resolution timer, for example ..
Offline iMo
  • Country: li
« Reply #23 on: September 14, 2021, 05:54:43 pm »
No problem, till may 2022 your ADR1000 will just pass the initial burn-in  :D
Offline MIS42N
« Reply #24 on: September 14, 2021, 10:29:45 pm »
I had a look at the application note. The pattern table they show for adding 3 bits is exactly what would be produced by the method suggested by Kleinstein, and implemented by myself to add 14 bits. Except for the line 3/8 which I suggest is an error.
It should be 0 0 1 0 0 1 0 1 which does not have 3 zeros in a row. The error is not repeated in 5/8.
In case anyone should stumble on this looking for actual code, I revised my crude example for the PIC and updated it for the enhanced 8 bit instruction set. In my defense, the original was written over 10 years ago as part of the first program I wrote for PIC. I hadn't looked at it since, except to modify the PWM register writes.
It may seem ludicrous to extend 10 bits to 24 bits, it is only useful when the output doesn't change frequently. At 40MHz the full pattern repeats in less than half a second, so if changes are made less frequently then the technique becomes applicable. In the particular application it is changed every few minutes. There is a project called picDIV which implies the PIC outputs have very little jitter, so it may be quite linear and accurate. I'll leave that to the metrologists.
BANKSEL PWM
MOVF    PWM+1,W
ADDWFC Dithr+1,W
MOVWF Dithr+1
ANDLW 0x40 ; isolate possible carry out
XORWF Dithr+1,F ; remove it from Dithr
ADDWF PWM+1 ; now the most significant 10 bits
MOVWF   PWM2DCL ; bits 0-5 ignored
CLRW
ADDWFC PWM+2,W
