Author Topic: Making step function in Opa transfer function  (Read 1097 times)
Online dobsonr741Topic starter
« on: June 25, 2023, 07:12:44 pm »
I’m looking to have a schematic to create the following DC transfer function:
Is should the precise in the linear 1 V/V region. Any ideas to share?
Offline magic
Re: Making step function in Opa transfer function
« Reply #1 on: June 25, 2023, 07:23:27 pm »
Get some LM358 or whatever dual opamp that works down to ground.
Wire one channel for unity gain with nonzero feedback resistor.
Configure the other as comparator. At low input voltages, the output goes up and pulls the unity buffer's IN- by means of a diode, overriding normal feedback and forcing its output to ground. At high input voltages, it goes down and the diode prevents it from disturbing the buffer.
Input impedance of the whole circuit is just two opamp input pins. High and constant over the whole range. But watch out for opamps with differential clamping diodes.
« Last Edit: June 25, 2023, 07:33:10 pm by magic »
The following users thanked this post: dobsonr741
Offline Terry Bites
« Reply #2 on: June 28, 2023, 09:44:34 am »
Keep it simple and DC accurate. An opamp free zone.
Compare Vin with your "dead zone" threshold using a comparator. Use that to control an analog switch. Switch between Vin and ground (or what ever level you like).
You can use what ever switches and comparators you prefer, single or dual supply- what ever suits. You may need a little hysteresis to reject false switching events.
If you want it to be bipolar use a window comparator.
Or be decadent and use an opamp with shutdown instead of the analog switch. eg OPA211 and many more shutdown types will work.
You do need a pulldown or other path to 0V, the outputs of these opamps go High Z when disabled.
« Last Edit: June 29, 2023, 07:21:12 am by Terry Bites »
