Get some LM358 or whatever dual opamp that works down to ground.
Wire one channel for unity gain with nonzero feedback resistor.
Configure the other as comparator. At low input voltages, the output goes up and pulls the unity buffer's IN- by means of a diode, overriding normal feedback and forcing its output to ground. At high input voltages, it goes down and the diode prevents it from disturbing the buffer.
Input impedance of the whole circuit is just two opamp input pins. High and constant over the whole range. But watch out for opamps with differential clamping diodes.
