Hi guys. I’m looking at building a galvanic isolator for my boat , the commercial ones all have poor monitoring solutions
Here’s the basic idea ( sometimes 4x diode drops are used )
This device is inserted into the PE line leaving the boat and prevents small DC currents from flowing , the capacitor is soley as a fail safe system if the diodes go open circuit.
What I want to do is monitor the diodes for two things
(A) a diode drop voltage appearing , which indicates there are currents flowing
(B) a detection system that detects the diodes have failed either open or shorted
The monitoring needs to be isolated for input into a micro
(a) is straightforward , (b) is where I could do with some ideas. I could inject a small dc current occasionally to test diode operation etc.
The solutions have to withstand the full fault mains voltage and current.
Any other thoughts on how to approach it.
