Hi guys, this is my first post here. I'm very much a novice electronics nerd compared to many of you so maybe you can answer this noob question kindly for me.
I'm working on an analog signal conditioning circuit for some RTD temperature sensors. I have 3 sensors and 3 conditioning circuits, each containing an LM324N quad op amp dip package for a current driver and some signal scaling. All 3 sections are powered from the same regulated 12v rail and ground.
The question:
Should I put 0.1uF and 10uF decoupling caps near the power pins on each dip package or just somewhere on the 12v and ground rails - location importance not withstanding? If each LM324N had a set of decoupling caps, wouldn't the capacitance all add up since they're in parallel on the 12v supply, resulting in filtering an unintended frequency range?
Thanks for the help!
