I appreciate your updates, but remain a bit confused over the dashboard.
Under parts, it lists: part categories 74, part types 1, attachments 3, and total parts 10. When I click it, I see BC182.
Part of this is obvious. you have 74 different part categories (resistor, diode, transistor, etc...), 3 attachments exist (datasheets I assume), 10 parts in the database, but what is the meaning of 'part type'?
When doing a part search in 'part meta search', I can't do a wild card. From what I understand, you've already added ten parts to the database, but, I can't seem to locate them easily enough in the 'parts' section so I can delete them. I attempted to do a wildcard so I can see which ones they are and manually delete them individually, but seems a wild card search didn't work.
Maybe it would help if you took a snapshot of the dashboard and commented everything as a tutorial for myself and others. The database itself is easy enough to learn, but maybe a snap shot of the dashboard explaining the meaning of each item would help.
As for the wild card search, my guess is the ten parts you have are scattered throughout different categories making it harder for me to delete them. I'd like to start with an empty database since then ten parts already in there aren't in my inventory, but also, I think being able to list every part could be beneficial.
As an example: if my inventory is 100 parts, but the database shows 101, I can do a wild card, see every part, and look for something that I may have entered incorrectly. Maybe I accidentally began entering a diode and saved it by accident, so a wild card list would show blank sections for that diode allowing it to stand out and delete it.
I'll admit though, I haven't tinkered with this much as I'm waiting for the Excel export feature. Although I could manually enter every part individually, at the moment I don't have time so it will be a project in the future, or once the import feature comes out.
Thanks again for all the work you're putting into this.
