Author Topic: (New photos added) Need help identify LCD panel connector type  (Read 1870 times)
Offline LoganTopic starter
« on: September 14, 2021, 01:04:32 pm »
Hi guys.
Anyone knows what type is this connector? Are there any IPS panel can work on this?
It seems have 32 pins, but are all 32 pin connectors compatible in protocol?
Thanks.
« Last Edit: October 18, 2021, 04:30:53 pm by Logan »
Offline Gribo
Re: Need help identify LCD panel connector type
« Reply #1 on: September 14, 2021, 04:14:52 pm »
Measure the contact pitch, this one looks like 0.5mm, but it can be also 0.4 or 0.635mm.
Also, there are top or bottom contact option, check which one is yours.
I am available for freelance work.
The following users thanked this post: Logan
Offline jpanhalt
« Reply #2 on: September 14, 2021, 08:26:21 pm »
Thanks.
What protocol?  Please give a link.  There is no requirement that all the tracks in a cable be connected.
Offline james_s
« Reply #3 on: September 14, 2021, 08:55:23 pm »
The type of connector used does not indicate anything about the type of interface, there is no standard.
Offline coromonadalix
« Reply #4 on: September 14, 2021, 11:58:25 pm »
surely not always the same protocol or the same pinout,  the only way to know  is to find the lcd part number  and or   finding the specs of the driver chip :  graphical ot text generator / driver chip  if the lcd doesn't come with it ...
Offline MegaVolt
  • Country: by
« Reply #5 on: September 15, 2021, 09:42:57 am »
FFC/FPC connector
« Reply #6 on: October 18, 2021, 04:20:34 pm »
I took more photos of the driver board(1,2) and a mark on back of LCD(3).
« Last Edit: October 18, 2021, 04:29:09 pm by Logan »
« Reply #7 on: October 18, 2021, 04:21:40 pm »
Are there any IPS replacement panel for this connector/protocol?
