Author Topic: Odd flat flex cable pitch  (Read 2982 times)
Offline HSPalmTopic starter
  • Country: no
« on: February 13, 2014, 12:56:41 pm »
just salvaged maybe 20 character LCDs from the e-waste here at work, some old ericsson office telephones. The connector cable is a flat flex cable with 12 pins. The two outer most pins measure 11mm center to center (or left side to left side, in the picture). So the pitch is 0.916mm, or 0.036 inches. Can't seem to find a matching cable or connector anywhere. Have you seen this dimension before?
Offline TerraHertz
    • It's not really a Blog
Re: Odd flat flex cable pitch
« Reply #1 on: February 13, 2014, 02:10:07 pm »
Are you trolling? Or just off by one?
12 pins, means 11 intervals between them. You're measuring 10.99, which should be 11.0
The inter-pin spacing is 1.0 mm
  • Country: no
« Reply #2 on: February 14, 2014, 01:30:13 pm »
Of course it was something obvious like this! Thanks for noticing, feeling a bit stupid now :)
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #3 on: February 14, 2014, 01:42:51 pm »
Day Job: Mostly LEDs
  • Country: no
« Reply #4 on: February 17, 2014, 07:28:50 am »
See Fencepost error
An example of this error can occur in the computational language Matlab
I feel much better now, thanks.
