You can find every part of the schematic on the die. Especially interesting are the input transistors P1/P2 and the current mirror transistors N1/N2. There are four times four input transistors criss-cross connected for low TC of Vos. N1/N2 are less meshed but still criss-cross connected.
In the middle of the die there is the biasing circuit which is used by both opamps, the right one and the left one.
At the lower edge there is the output stage.
The output bondpad and the Vdd bondpad are equipped with a ESD protection MOSFET. While the "normal" MOSFETs have silicon gates this one has a metal gate. The thicker gate oxide increases the threshold voltage so that the MOSFET conducts at higher voltages. The line into the opamp circuit isn´t connected directly to the bondpad but to the doped area of the MOSFETs. That gives you a little higher impedance for an ESD pulse.
At the input bondpads there is an additional protection with a series resistor and a small component, probably a zener diode.
The input MOSFETs have circular gate electrodes.
The criss-cross connection made the interconnection quite complex.
The n-MOS of the current mirror have bigger gate electrodes than the p-MOS at the input. Interesting...
The source resistors of the current mirror are placed left of the transistors. The datasheet describes a "Trimmed Offset Voltage". If you want to tune Vos you have to tune these source resistors but it´s impossible to tune resistors this small.
And I didn´t find an other tunable circuit on the die.
In the line under "Trimmed Offset Voltage" the datasheet describes the Vos of the TLC277. Perhaps the TLC277 die is different and tuneable.
In the upper right corner there are the two zener diodes.
Lowside current mirror of the reference circuit.
At the lower edge of the picture there is the highside current mirror.
The two big transistors on the left side are the two current sources for the left opamp (...on the right side for the right opamp).
Between the current sources there are some smaller transistors not shown in the schematic. That´s probably a startup circuit.
The feedback resistor R5 is interesting: It travels a long way through the circuit.
The feedback capacitor C1 is built with three electrodes. The output (green) is connected to the upper and the lower electrode (blue). The resistor R5 is connected to the electrode in the middle (red). The upper electrode is split and connected with a metal rectangular (black). That´s probably a way to tune the capacitance.
The highside transistor (red) and the lowside transistor (blue) are integrated in the same area. The highside transistor is a little bigger.
The resistor R6 is a wide stripe between the output transistor and Vdd (red). There is a metal plate on top of this resistor. The plate is connected to Vdd with a resistor (yellow). On the right side there is a strange part (green) between the plate and Vdd.
My best guess is that this metal is kind of a gate electrode that bias the resistor.
https://www.richis-lab.de/Opamp39.htm
