I'm facing some difficulties trying to design an optical serial adapter for an existing piece of gear. Having only done a few IR adapters before, I've never ran into any issues with speed or sensitivity before, however this time it's just not working out. The transmitter on the device side is a small visible red LED, as the receiver for it, I can pretty much only cram an 0805 or 1206 there. Having tried Kingbright KP-2012P3C and Vishay TEMT7000X01, both give unacceptable results - depending on the current I either get nearly non existent sensitivity or an unusably "round" signal at 9600 baud. Setting the load resistor to about 8k? from a 5V supply gives the most optimal result, where the signal is sometimes readable. The rise and fall times are so bad, I'm essentially getting runt pulses.
