Though, I am very interested what kind of equipment do you use at home for surface mount soldering. I was using hot air gun + electric grill + soldering iron + solder paste for those bad PCBs.
A hot plate using the reflow method works pretty well:
1. Get a Solder mask - Laser cut stencil (
http://www.ohararp.com/Stencils.html)
2. Get Solder Paste (
http://www.zeph.com/zephpaste.htm - Need to keep refrigerated)
3. Clamp or tape solder mask to PCB board and apply Solder paste to all SMT contacts
4. Remove solder mask and place PCB on a metal pan or metal plate (you can buy Alum plate from
www.onlinemetals.com)
Place SMT devices on PCB board. I use tweezers and a desk magnifier for small SMT devices (ie 805 402, etc)
5. Move PCB with metal pan\plate on to hot plate. Turn on hot plate until solder melts. turn off hot plate and move metal pan\plate off the hot plate (place on pot holder so it does damage your counter\desk).
Alternatively you can apply solder (using solder wire and solder iron) to each SMT pad and then add the SMT parts and use the hot plate to reflow the solder. This will avoid the costs for using solder paste. But this method is only effective with large SMT parts such as 1206, 1812,2010, and SOIC). Smaller parts (ie 402, TQFP) are harder to place because the solder iron leaves an uneven surface that prevents the parts from stating in the correct place. Perhaps if after you apply the solder, you heat up the PCB using a hot plate the solder will even out over all of the pads before applying the SMT parts to the board (I have not tried this).
Tip: for small SMT devices after applying solder paste, check for solder bridges between pads on small devices. Sometimes the solder paste moves when you remove the solder mask stencil or paste gets underneath. You can remove the excess with a dental pick (sold by most online SMT soldering suppliers) or an exacto knife.
Tip: I store my Solder mask stencils in ziplock baggies after use. I lay down paper over the work area to trap any excess solder paste. Remember that the solder paste contains lead or other heavy metals. Some of the lead freel solder may contain other poisonous heavy metals. Always assume all solder contains toxins. Its very easy to contaminate yourself or others with solder paste since it sticks to everything. Its very easy to get it on the floor that might be picked up by small children or pets when they touch the floor with their hands or paws and lick their paws\hands or touch food.
Note: that some some lead free solders are suspectable to tin-whiskers that form over time and can create bridges beween connections:
http://en.wikipedia.org/wiki/Solder""Tin whiskers" were a problem with early electronic solders, and lead was initially added to the alloy in part to eliminate them."
Tip: If you use non-lead solder and you expect your PCB to be operable over 5 years, I recommend applying a conformal coat over the PCB after you finished the board. The conformal coat (usually spray Poly Urethane) will help prevent the formation of tin whiskers from forming. But conformal coats make it difficult to rework the board since all of the connections become coated with plastic.
