Author Topic: Pcb Test Design  (Read 1274 times)
Offline RasklncTopic starter
  • Country: tr
Pcb Test Design
« on: May 16, 2024, 09:33:36 pm »
I am making electronic circuit design but the PCB test takes a lot of time. I thought if I design a test circuit I could be earning time. What do you think about these project? Do you have any idea or how can I make ıt ?
If I design test card only one circuit I can't use other design. I want to one card for the a lot of PCB card
Offline Konkedout
Re: Pcb Test Design
« Reply #1 on: May 17, 2024, 04:58:24 am »
I don't understand what you are requesting, and I guess others feel similarly.  Are you trying to design a pcb to test a pcb?   If you want a better response, please give more detailed information as to what you are trying to do.
Offline Mark
Re: Pcb Test Design
« Reply #2 on: May 17, 2024, 09:32:37 am »
Offline tooki
Re: Pcb Test Design
« Reply #3 on: May 17, 2024, 10:23:56 am »
I’m thinking they want a universal test bed.
Such things already exist, but they cost a fortune.
Offline aliarifat794
  • Country: bd
Re: Pcb Test Design
« Reply #4 on: May 17, 2024, 05:58:39 pm »
If you want an universal test bed like someone guessed here, you can make a PCB tester. A PCB tester will help you test all PCBs. You can perform short circuit test with a PCB tester. You can also check for broken traces with the tester. If will help you easily find faults with your PCB. You can make one such device following this design here.
https://www.pcbway.com/project/shareproject/Miniature_PCB_Tester_c2b226d2.html
It's a miniature PCB tester. It is based on ATTINY45-20PU from Microchip Technology. While a simple project, one thing that seemed clever was the way that the two output pogo pins/LED was mounted. The 3D-printed fixture is designed to hold the LED leads like a spring.
Offline tooki
Re: Pcb Test Design
« Reply #5 on: May 19, 2024, 08:34:40 am »
But that isn’t universal, it’s a classic tester that is specific to a PCB.
