If you want an universal test bed like someone guessed here, you can make a PCB tester. A PCB tester will help you test all PCBs. You can perform short circuit test with a PCB tester. You can also check for broken traces with the tester. If will help you easily find faults with your PCB. You can make one such device following this design here.https://www.pcbway.com/project/shareproject/Miniature_PCB_Tester_c2b226d2.htmlIt's a miniature PCB tester. It is based on ATTINY45-20PU from Microchip Technology. While a simple project, one thing that seemed clever was the way that the two output pogo pins/LED was mounted. The 3D-printed fixture is designed to hold the LED leads like a spring.
