I'd like to measure the vibration (frequency, intensity) of an object thru contact. I have heard about piezo sensors that can do this. However, I wonder if the result would vary based on the pressing force between the sensor and the object?
The object position can vary a bit so if I use an actuator to push the sensor to the object, the contact force might vary.
Please advise on any feasible approach.
Thanks
