The detector has two elements inside and it's the difference of those in thermal radiation that triggers it.
If the detector is without a lens:
- illuminate the other half with a bulb or heater resistor (like 5W resistor dissipating 4W) at 5-20cm distance
- add a shutter that opens slowly right in front of detector, exposing first the other half and then the other
If there is a lens:
- Have a warmed up +10°C over ambient painted (not clear metal, as its emissivity is low) plate in front of sensor (50-100cm)
- Add similar shutter closer to the plate rather then closer to the plate
Doing this well without moving parts may be difficult depending on the frequency (or rather time) response of the sensor electronics.
